I have a web cam I converted to a night vision camera by removing the infrared filter. The software I tested it with is Virtual Dub but it only records in .avi which takes up a lot of disk space. I may be recording for hours at a time and am looking for something that captures as .mpeg so I can get more video per GB.
I am looking for a good (and hopefully free) video capture program I can use to capture video from my web cam and am having trouble locating the software portion of this site. This is for Windows by the way.
You can change to another compression in virtualdub, under video->compression choose for example the xvid codec. Adjust the xvid video bitrate settings for lower file size.
Thanks a million. Downloaded the codec and it went from ~25MB per 5 seconds of video to ~25MB per minute of video. That's going to make a huge difference.
Again, thanks.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Looking for Good VCR for Capturing
By zerowalker in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2011, 17:56 -
Good software for capturing DV with Canopus ADVC 110?
By nikgelfi in forum Capturing and VCRReplies: 12Last Post: 28th Apr 2011, 08:39 -
What Software is out there that's really good for capturing?
By TheHour in forum Capturing and VCRReplies: 22Last Post: 28th Feb 2008, 15:38 -
Good software?
By MTD in forum Authoring (DVD)Replies: 2Last Post: 30th Jul 2007, 12:25
