I've got some MKV files with subtitles... I want to convert these to MP4 so that I can import them to the iPad and pay them through Video.app to my TV using Apple's iPad-to-TV cable (the Composite AV cable).
I can see the subtitles in VLC on the Mac. I can see the subtitles in VLC on the iPad. But VLC on the iPad can't play out to the TV through the cable.
I've got:
Aimersoft Video Converter Ultimate
Aimersoft Total Media Converter
MKVTools
iSkysoft Video Converter
But not matter what I do, I can't seem to find a recipe to convert to MP4 while burning the subtitles to the video.
Can anyone help? Many thanks in advance.
Results 1 to 11 of 11
OK, but with such a terse reply I can only hope that I guess right on the settings.
I loaded the file. Under the Subtitles tab under Track there was "Foreign Audio Search - (Bitmap)" which when selected allows "Forced only" and "Burned in" to be selected. Also under that track was "0 - English - (Text) (UTF-8)" which when selected did not allow such choices. I am converting with the former selected and ... hope. -
I am often convert .mkv to .mp4 for my PSP with FormatFactory. It IS has some flaws, but here no many such tool anyway.
1) FormatFactory MUST be version 2.45 or less. Unfortunate, later 2.50 and 2.60 version contains BUG and i am can not see video on PSP at all.
2) Each time you start FF 2.45 you MUST set video and audio bitrate. Another bug - FF do not remembered it and default values too low.
All other aspect is OK. You can choose subtitles in property (see context menu). -
What should I do, now? Find a way to burn the subtitles onto an AVI and then convert that to MP4? I've tried nearly everything I can think of.
Go to MPayer HQ http://www.mplayerhq.hu -> Related Project. Search for Mencoder frontend. I am see at least two, for example: ffmpegX http://homepage.mac.com/major4/. If any frontend do not support subtitles - you always can use Mencoder for OSX with appropriable command line. See example in internet, command line is not too hard, you just copy command line from some forum and replace video filename and track numbers.
It's not just a front end I need. What I need to do is convert an MKV with subtitles to an MP4 with subtitles that Video.app on the iPad can play, so that I can view the video with subtitles on my television.
Aimersoft wrote to me and said that they do not support "external subtitles".
So what I need is a recipe to take the MKV with subtitles and convert it perhaps to AVI with burned in permanent subtitles, that I could then get Aimersoft to convert to MP4 which my iPad needs.
But I cannot find a way to do this on Mac OS 10.6.6. -
avidemux. But it's not that simple, you must demux the subs from the mkv with mkvtoolnix In avidemux add a subtitle filter and load the sub, choose video compression like h264 and save as a new mp4.
Try TRY before complains. PSP not supported external subtitles too and i am convert anime from .mkv with mencoder a lot.
It is rather inconvenient method, but this method WORK. Try frontend for mencoder. If no luck - try google for "mencoder avi mp4 ipad hardsub with subtitles" or something similar. Find command line and use it. I am not have Mac or iPad and can not check it, but this approach is right.
mkv to mp4 with subtitles
By SKFb in forum Video ConversionReplies: 3Last Post: 8th Oct 2011, 16:57 -
MP4 to MKV with subtitles
By Zhuge Liang in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 13:33 -
.Mkv to .Mp4 with subtitles
By ericsimaginaryfriend in forum SubtitleReplies: 1Last Post: 24th Oct 2010, 00:11 -
mkv to mp4 with subtitles at the top!
By felix in forum Video ConversionReplies: 1Last Post: 13th Jan 2010, 09:26 -
MKV to MP4 with subtitles
By MasterRoshi in forum Video ConversionReplies: 4Last Post: 4th Sep 2008, 19:17
