I downloaded the Huffyuv Codec and installed it...
In normal mode I can see the codec at Virtual Dub but as soon as I switch to Capture mode, and like to choose a compression the Huffyuv codec doesn't show up... Any ideas?!
Do any codecs show up at all? If you're trying to capture from a firewire port, VirtualDub may not be able to do that. I haven't been able to get it to recognize any codecs when I try to capture from firewire, even though a screenful show up when in normal conversion mode.
What format are you capturing under YUY, RGB24,... certain codecs do not appear with certain formats.
Thanks, the solution was that I had RGB 32bit format, now I changed it to 24 bits and now I can see the codec!
I appreciate it!
No Huffyuv Codec under VirtualDub Compression
By Ryutso in forum Capturing and VCRReplies: 7Last Post: 28th Jan 2011, 02:31 -
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 16:43 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 15:12 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47
