Try StreamFab All-in-One and rip streaming video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
    Feb 2011
    Saskatchewan, Canada
    I am new to ffmpeg, although it is working for the most part.
    I have a video, I output it to a jpeg picture array using the following command:
    this seems to provide equal quality to the original video.
    then when I recompile the jpegs back into video no matter what I set the frame rate at, the video length is 4 minutes instead of 2 minutes and 30 seconds like the original. I use the following command:
    ffmpeg -i foo-%03d.jpeg -r 29.97 -b 8973kb -minrate 8973kb -maxrate 8973kb -bufsize 10000kb foo2.mp4
    Does it create additional frames from the source frames to accommodate the fps? Is there a way I can specify how long the video should be? Also I should note that when I play the compiled video in MPlayer it always shows the fps as the value I set in the command line parameter, however the video length is always the same value.
    help!
    thanks...
    Feb 2011
    looks like I solved my own problem... I used the following command:
    ffmpeg -r 30 -i foo-%03d.jpeg -r 30 -b 8973kb -minrate 8973kb -maxrate 8973kb -bufsize 10000kb foo2.mp4
    I tried one similar to this using a -r value of 29.97... but it turned out having a video length of almost 2 hours. I don't think that it divides single images properly... so I thought I would just bump it to 30 fps and see what happens... and it worked.
    Jul 2009
    Spain
    There's no reason your command shouldn't also work with -r 29.97.
    In fact, the second -r is unnecessary - the important thing is to set the input frame rate (otherwise it defaults to 25), which will also become (by default) the output rate. So this should work:
    ffmpeg -r 29.97 -i foo-%03d.jpeg -b 8973kb -minrate 8973kb -maxrate 8973kb -bufsize 10000kb foo2.mp4
