Not as far as I know. You'll have to demux the audio as WAV, open it in a WAV Editor (Audacity, for example), mute whatever you want in there, and then add the edited audio, perhaps after reconverting back to whatever it was earlier (AC3, MP3, whatever), back into the video.
And if I'm wrong about not being able to do it directly in VDub, I'm sure someone will come along and correct me. -
Yes, but that requires reencoding the video too.
Best way is it demux the audio and edit it, and then replace the old audio with this using VDub.
If the audio is MP3, you can edit and change volume in MP3DirectCut with no degradation. -
It is possible with Virtualdub but it's a lot of work. You'd have to save segments of the video and piece them together. You'd need to use smart render also unless you can cut on key frames. Under Audio, in Full Processing Mode, click the Volume button and click "Adjust volume of audio channels" and move the slider all the way to the left. This will mute the audio.
It would be easier to do this with an audio editor like others have suggested.
[VirtualDub] How to split avi to x parts with one operation?
By ralf07 in forum Video ConversionReplies: 3Last Post: 5th Apr 2012, 17:01 -
How to apply filters in VirtualDub to only *parts* of the video?
By maskingtape in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 02:19 -
Delaying parts of an audio stream (vdubmod)
By denadel in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2010, 06:16 -
Editing parts of the audio on VirtualDub
By ione in forum AudioReplies: 5Last Post: 19th Sep 2008, 04:57 -
Joining a movie with 2 parts together using virtualdub!!!
By SaM*T in forum EditingReplies: 1Last Post: 17th Sep 2007, 14:09
