I am trying to convert a .MOV file to an FLV file. I drop the MOV file, choose FLV, and choose 16:9 format. When I click encode, it instantly "dings" and there is a zero KB file created.
Can anyone suggest what I may be doing wrong or why this is happening?
Thank you so much in advance for your assistance.
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Thu Feb 3 16:06:12 CST 2011
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/scottross/Desktop/TeamLiftOff YouTube.m4v':
Duration: 00:08:11.9, start: 0.000000, bitrate: 1636 kb/s
Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
Stream #0.1(eng), 30.00 fps(r): Video: h264, yuv420p, 640x400
Codec type mismatch for mapping #0.0 -> #0.0
1/ You don't have to convert MP4 to FLV for embedded web playback. The Flash Player plugin (v9+) will play MP4, just like FLV.
2/ The "Codec type mismatch for mapping #0.0 -> #0.0" error points to the stream order in your source file (audio stream before the video stream), which the (old) version of ffmpeg inside ffmpegX can only deal with when told about it. The usual fix for this error is to set "Invert mapping" in the Audio tab. Then ffmpegX will convert each stream as intended.
However, there seems to be a bug or incompatibility that makes the conversion to FLV when also setting "Invert mapping" less than useful, as the output FLV seems to "stutter" in embedded web playback.
One workaround has been to reverse the stream order in QuickTime Pro, so that it "Invert mapping" doesn't have to be used in ffmpegX.
Case,
Thanks. I realize that I don't need to convert MP4 to FLV for internet streaming. That was the last conversion I tried. I was just trying to use different formats to get an FLV file thinking perhaps it would work with something other than FLV. I need an FLV file for the web meeting service that I use. It only accepts FLV files.
I tried to do a .MOV to .FLV and this was the result:
Encoding started on Sun Feb 6 14:52:39 CST 2011
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/scottross/Documents/WorldVentures/Webinars/01.12.2011_ScottRoss_US_Pres_SHORT_H264.mov':
Duration: 00:05:52.8, start: 0.000000, bitrate: 1038 kb/s
Stream #0.0(eng): Audio: aac, 48000 Hz, stereo
Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 640x360
How do you invert the audio/video in Quicktime?
You could try that service with a renamed file: foo.mov --> foo.flv.
It is possible that this may work, as the FLV format allows H.264 video and AAC audio, just like this MOV file has. If it works, then that would be the easiest solution. Worth a try, perhaps?
The workaround link points to an older post on this forum which tells how to invert the streams. You need the Pro activation for this kind of editing, as well as for saving the result to a new file.Originally Posted by hopeisnotastrategy
problems converting MOV -> FLV
By dannyboy2090 in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2010, 13:50 -
converting .mov to flv pixelating and jumpy
By Leonski in forum ffmpegX general discussionReplies: 1Last Post: 1st Oct 2010, 12:55 -
help converting MOV to FLV and aspect ratios
By erichazann in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2009, 14:16 -
Issue converting a .mov to a .flv
By bopdro in forum ffmpegX general discussionReplies: 1Last Post: 5th Mar 2009, 13:15 -
Help converting .MOV to .FLV
By fritzthird in forum ffmpegX general discussionReplies: 2Last Post: 19th Apr 2008, 14:00
