Hello all, I am a newbie when it comes to video converting and the associated stuff.
I have 3 .iso files and after mounting with power iso i can see AUDIO_TS and VIDEO_TS folders containing a lot of vob, bup, ifo files.
What i want to do is convert each .iso file into a separate dvdrip. I'm a total newbie at this so could you please tell me the procedure on how to do that via simple noob understandable steps?
Also could you please tell me which video format would be the best for the rip.
Thanks in advance.![]()
Results 1 to 16 of 16
DVD Shrink can open the iso and also join them all, http://www.mrbass.org/dvdshrink/flipper/
If you want to keep the menus you can use dvdremake pro, http://www.dimadsoft.com/dvdremakepro/ht_merge_full.php
Or do you want to convert to some other format? Like avi divx/xvid? -
Thanks for the reply, but what i want actually is that I want to convert the many .vob files in a single .iso file into a single dvdrip file with extension like avi, mpeg, because the vob files take up huge amounts of space. Can you tell me what the best extension would be for it?
Now that you've given a link on how to combine the vob files, can i just combine them and then convert the one final file into the avi, mpeg format?
Also, are the bup and ifo files of any use? -
Fairuse Wizard, Autogk, Staxrip, Xvid4psp
But noone will make a single avi from all. No such software exists. -
Just keep the ISO mounted and follow Baldrick's suggestions. And in the future forget about those VOB files in the VIDEO_TS folder. Those are NOT your target. Your target is to convert that complete DVD to a single compressed file...not those individual VOB files.
Baldrick said that one single video file cannot be made. But people make dvdrip of music dvds on the net. I have seen both .iso versions and .avi versions of those dvds. Please help, i need to convert a 20gb dvd consisting of 3 .iso's into 3 separate avi's.
My Solution> Mount Iso> Open dvd decrypter or dvdfab and extract the dvd folder > then use any gui to convert to avi, mkv.
My Preference to mount: daemon tools lite(free) -
Mounting the ISO reveals the VIDEO_TS folder....so why would anyone in their right mind open that with DVDDecrypter to go to an .AVI file when DVDDecrypter does not do AVI files?....and neither does the free version of DVDFab(DVDFabDecrypter)?
And you don't need to mount an ISO as both those programs will open an ISO directly
Way to many extra steps to get from A to B
how to convert a dvdrip to high quality
By lordrt in forum Video ConversionReplies: 4Last Post: 25th Jul 2011, 07:30 -
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 00:32 -
how to convert dvdrip avi's to vcd
By kissme1 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 9th Dec 2008, 15:19 -
how to convert iso to single layer dvd (4.7)
By roboroach in forum MediaReplies: 4Last Post: 1st Dec 2008, 12:44 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01
