I was wondering if someone could help me. I'm trying to duplicate some of my dvd's that are dual layer. I've read up on the ways to do it, (seems to me like it's easier to buy a duplicate of my dvd in the store than go through the long time process of converting to fit on a 4.7.) Is there a program or an easier way than ripping and changing the bitrate manually, to make a 7gb dvd movie fit on a 4.7 gb dvd that will do this automatically? Or is there a program that will automatically split the dvd in two so that it can be put on a 9.4gb hard drive?
Also I've seen this formula floating around...
Rip with smartripper
get d2v and wav with DVD2AVI
use d2v in TMPGenc to make 29.97 fps ntsc m2v file.
use bitrate calculator to know what rate to encode at, based on the length, and desired filesize (disc size - 400mb - wav)
make a few menu pages and buttons
stick m2v and wav into dvd authoring program
burn.
I'm Using an Apple SuperDrive (Is this even possible with IDVD2)
Thanx
the best way is to use the guide on this site http://www.vcdhelp.com/DVD2DVD-R%20bigger%20than%204500%20megs/ it does take a while but it will give the best results and i tried them all
DVD+R DL Duplication
By sfxssorce in forum MediaReplies: 2Last Post: 10th Jan 2012, 00:42 -
cd-r image duplication
By tealmarlin in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2009, 16:29 -
I am Bit confuse with cd duplication..
By Sophias012 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 4th May 2009, 18:36 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27 -
DVD duplication house
By crazymoney in forum Authoring (DVD)Replies: 2Last Post: 16th Oct 2007, 19:04
