Hello all,
I was wondering if there was an app out there that could convert an flv file to another video vile, preferably avi or mpg (but wmv is fine too, for example) quickly. Meaning, without having to render the whole file (direct stream copy/convert?)?
Anyone know of such a thing?
try avidemux or winff. I was instructed by bat999 that if the flv is h264 video winff can take a flv and transcode it to mp4 or a few other extensions without reencoding. I'm not sure of its limitations but that would be something to check out. I have used winff successfully to transcode h264 flvs to h264 mp4 without potentially problematic reencoding.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I use FFmpeag to do the reverse of what you are asking, but you can simply alter your command line:
Mine:
ffmpeg.exe" -i "c:\Documents and Settings\blah\SANY0075.mp4" -vcodec copy -acodec copy "c:\Documents and Settings\blah\SANY0075.flv"
It's a simple copy of both audio and video codecs. You just are changing the container in the above example.
Your's would look like:
ffmpeg.exe" -i "c:\Documents and Settings\blah\SANY0075.flv" -vcodec copy -acodec copy "c:\Documents and Settings\blah\SANY0075.mp4" -
If you want it to be mpg (mpeg 2) it will need to be transcoded and a simple copy codec won't do the trick.
How to convert .flv (flash video) to .avi or .mpg
By hitrec in forum User guidesReplies: 181Last Post: 17th Apr 2010, 16:14 -
How to convert MPG with AC3 audio to FLV? --> HELP
By CineManno in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2008, 02:56 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 00:14 -
How To convert .flv videos to mpg format
By rbtechno in forum Video ConversionReplies: 1Last Post: 17th Nov 2007, 04:15 -
How to convert *.flv to *.mpg files ?
By trip_at_high in forum MacReplies: 3Last Post: 2nd Nov 2007, 05:41
