first of all please excuse my English
okay here is my problem i downloaded Avatar movie 7.93GB MKV and i want to watch it through PS3 (HDD external)
by using Tsmux i noticed that the Audio is dts and as far as i know ps3 doesn't support dts Audios so i demux the audio and convert it to Aac (Format Factory), through Tsmux i opened the MKV file by clicking "add" and remove the dts audio and here is the strange part when i click "join" and choose the Aac file that i converted it gives me this message "Appended file must have same file extension." but when i click "add" the Aac file goes in just fine, Split and cut every 4GB and Output Blu-ray disc then start muxing after that it works perfectly on PC but in ps3 there is no audio at all only video i even tried converting the dts to MP3 but its the same no audio in ps3.
here is the original MKV
General
Complete name : C:\Documents and Settings\user\Desktop\BitLord\Downloads\Avatar.200 9.EXTENDED.720p.BluRay.x264-BestHD\besthd-avatar.extended-720p.mkv
Format : Matroska
File size : 7.94 GiB
Duration : 2h 58mn
Overall bit rate : 6 377 Kbps
Writing application : x264.exe
Writing library : mkv2rls v1.3 (date: 2010 aug 28)
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 57mn
Bit rate : 4 741 Kbps
Nominal bit rate : 4 867 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.215
Stream size : 5.89 GiB (74%)
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4867 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 58mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 1.88 GiB (24%)
Title : English DTS
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English Forced
Language : English
Text #2
Format : UTF-8
Title : English
Language : English
Menu
00:00:00.000 : en:00:00:00.000
00:05:25.575 : en:00:05:25.575
00:10:12.278 : en:00:10:12.278
00:10:24.457 : en:00:10:24.457
00:10:37.303 : en:00:10:37.303
00:11:47.916 : en:00:11:47.916
00:15:59.208 : en:00:15:59.208
00:17:54.782 : en:00:17:54.782
00:23:54.892 : en:00:23:54.892
00:27:54.548 : en:00:27:54.548
00:28:02.556 : en:00:28:02.556
00:28:45.223 : en:00:28:45.223
00:30:14.021 : en:00:30:14.021
00:30:27.617 : en:00:30:27.617
00:32:04.464 : en:00:32:04.464
00:32:27.904 : en:00:32:27.904
00:37:16.526 : en:00:37:16.526
00:39:08.054 : en:00:39:08.054
00:41:18.476 : en:00:41:18.476
00:47:43.319 : en:00:47:43.319
00:48:09.178 : en:00:48:09.178
00:49:16.912 : en:00:49:16.912
00:53:05.015 : en:00:53:05.015
00:54:22.009 : en:00:54:22.009
00:55:42.214 : en:00:55:42.214
00:57:44.044 : en:00:57:44.044
00:58:32.050 : en:00:58:32.050
01:01:09.416 : en:01:01:09.416
01:03:09.619 : en:01:03:09.619
01:03:57.208 : en:01:03:57.208
01:07:03.227 : en:01:07:03.227
01:09:40.635 : en:01:09:40.635
01:11:50.222 : en:01:11:50.222
01:15:18.889 : en:01:15:18.889
01:15:53.799 : en:01:15:53.799
01:17:32.231 : en:01:17:32.231
01:18:07.891 : en:01:18:07.891
01:22:38.120 : en:01:22:38.120
01:25:59.488 : en:01:25:59.488
01:26:12.709 : en:01:26:12.709
01:27:42.299 : en:01:27:42.299
01:27:54.436 : en:01:27:54.436
01:33:00.408 : en:01:33:00.408
01:36:03.424 : en:01:36:03.424
01:37:36.642 : en:01:37:36.642
01:37:36.893 : en:01:37:36.893
01:44:15.291 : en:01:44:15.291
01:46:49.236 : en:01:46:49.236
01:48:14.029 : en:01:48:14.029
01:48:58.198 : en:01:48:58.198
01:50:02.596 : en:01:50:02.596
01:51:53.582 : en:01:51:53.582
01:58:30.895 : en:01:58:30.895
02:02:13.284 : en:02:02:13.284
02:07:51.664 : en:02:07:51.664
02:09:30.554 : en:02:09:30.554
02:12:36.615 : en:02:12:36.615
02:16:03.363 : en:02:16:03.363
02:19:31.655 : en:02:19:31.655
02:23:59.631 : en:02:23:59.631
02:30:05.079 : en:02:30:05.079
02:32:13.291 : en:02:32:13.291
02:32:59.212 : en:02:32:59.212
02:33:56.852 : en:02:33:56.852
02:34:52.908 : en:02:34:52.908
02:40:02.259 : en:02:40:02.259
02:40:45.886 : en:02:40:45.886
02:41:03.987 : en:02:41:03.987
02:45:33.215 : en:02:45:33.215
02:46:30.814 : en:02:46:30.814
02:46:48.498 : en:02:46:48.498
02:48:56.793 : en:02:48:56.793
02:49:11.725 : en:02:49:11.725
02:51:32.073 : en:02:51:32.073
and here is the m2ts file after converting (mp3 audio)
2 parts came after converting because of split and cut this one is the first part
General
Complete name : J:\Movies\Avatar\BDMV\STREAM\00000.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 3.72 GiB
Duration : 1h 41mn
Overall bit rate : 5 238 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Duration : 1h 41mn
Bit rate : 4 867 Kbps
Height : 720 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.220
Stream size : 3.48 GiB (93%)
Language : English
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Duration : 1h 41mn
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 93.2 MiB (2%)
Text #1
Menu ID : 1 (0x1)
Format : PGS
Language : English
Text #2
Menu ID : 1 (0x1)
Format : PGS
Duration : 1h 41mn
Video delay : 39s 789ms
Language : English
Closed Thread
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
[Help] Blu-Ray > MKV > Hardcoded Vid & Sub > MKV > PS3
By psionicsin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2011, 02:07 -
1080p Mkv To DVD-DL 8.5 Gig To Play On PS3 and Blu Ray
By Chevy434 in forum Authoring (Blu-ray)Replies: 5Last Post: 20th May 2010, 04:04 -
mkv, x264, and h.264 to blu-ray to play on PS3
By cyberpimp16 in forum Authoring (Blu-ray)Replies: 1Last Post: 14th May 2009, 14:58
