Hi this is an annoying problem..I have put a lot of my DVDs onto an external hard disc by ripping them and then converting them to divx and mp3 as my TV has a usb connection and supports the said file types. I convert using imtoo convertor ultimate. When converted they are saved to my ext hdd I plug it into the TV and it will play no proble, however After about 20 Mins it stops and goes back to the start. If I goto where it stops and play it it will play the rest of the movie. It does it with them all. I have tried ntfs and fat32 file systems ans the same thing. The convertor is fully licensed and the ripper being xillusoft dvd ripper is too
I would be greatful of some help...thanks
How big are your avi divx files? Try stay below 2gb.
They tend to be around 4GB to 7GB but why would that make a difference, is it because I am converting from dvd to hd if I convert to standard divx the file size is around 1.5GB?
Does the 1.5gb files play fine?
And I wouldn't convert to any hd resolution, 720x540(4:3) or 720/406(16:9) is enough. -
Its a perfect picture and audio which is in sync at 24fps but it just halts then stops and that was at 1240x720 in hd divx.... With one I recopied and the glitch wasn't at the same point so its a puzzle to me also its not on a loop or split files....
Well your advice was great file size around 1.5GB and played right through, audio is spot on but I do get a bit of pixilation at times not sure what I can do with that and keep a low file size?
Problems with ISO file backup from HDD to HDD
By badboytim999 in forum Newbie / General discussionsReplies: 7Last Post: 15th Dec 2011, 09:03 -
Free program to copy Movie dvd`s to my portable hdd
By rob74 in forum DVD RippingReplies: 4Last Post: 5th May 2011, 16:14 -
Problem viewing a movie on a DVD
By oren21 in forum Newbie / General discussionsReplies: 6Last Post: 31st Oct 2009, 12:23 -
Problems with LG HDD/DVD Recorder 780
By cbgman in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2008, 15:27 -
Sony HDD dcr sr45 windows movie maker codec problems
By iflyhigh in forum EditingReplies: 1Last Post: 30th May 2008, 12:09
