I noticed Pinnacle Studio 9.4 hanging after sitting idle for a period. It captured fine, even made movies. But if it sat for a period something happened to it. Couldn't even close it with task manager (Running XP pro).
I assumed it was an issue with Pinnacle, so I installed WinDV to capture, it started doing the same thing. If it sits idle, it becomes inoperable and you can't close it, the computer won't shut down or restart, have to hit the reset button.
I assume it's related whatever common thread there is between the two apps.
Any suggestions?
Thanks.
Pro Audio To Go...use your phone for recording?
By bahner in forum AudioReplies: 17Last Post: 17th Apr 2012, 00:25 -
Free apps for Sony Vegas Pro?????
By ingeborgdot in forum EditingReplies: 4Last Post: 12th Jan 2011, 11:21 -
Intensity Pro Gradually Desyncs in capture apps, please help!
By swiftor in forum Capturing and VCRReplies: 5Last Post: 30th Aug 2010, 19:50 -
uploading multpile files in one sitting ? ... [gave up on]
By vhelp in forum FeedbackReplies: 0Last Post: 18th Jan 2010, 17:37
