I am tired of my slow Pentium 4 1.6 ghz computer taking over 6 hours to convert 4 hour AVI movies to DVD. All video rendering is way too slow. And I'm going to be video editing even more now that I have a digital camera with HD video.
Could anyone recommend what processor or GPU I should get so that I can increase the speed of rendering substantially. My budget is around $300 so obviously I can't get the best that money can buy but I should still be able to get something better than what I have to cut down this slow rending time. I was thinking like one of the AMD Phenom or AMD Athlons because price per performance is a lot better. Also, someone told me that a good GPU will render at least 10 times faster than a processor. Any recommendations on that would be great too.
$300 for a whole system?
for the CPU u need a new motherboard,memory,and a PSU like 500/600 w and up
AMD Athlon II X4 640 $99
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 $65
GIGABYTE GA-880GMA-UD2H motherborad (video on board) $99
here goes your $300
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128445
wait .you have $35 left.lol .Rosewill RD400-2-DB 400W $34.99(sorry no CORSAIR PS for you
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182074Last edited by MJA; 2nd Feb 2011 at 01:21.
You will likely also have to add in a operating system and some hard drives.
If you are just running a 32bit OS, 4GB RAM will be a bit cheaper, ~$40US. A 32bit OS can't use more than 4GB RAM.
That's a good MB and you don't need a separate GPU as the CPU can do the encoding. I'd like to see a GPU that can encode ten times faster than a CPU (At the same quality). Don't believe everything you hear.
A 500W PS should be plenty. I wouldn't go cheap there as you could loose the MB and everything else if it fails catastrophically. -
You have to take into account which codecs you will be using. GPU acceleration probably wont help you unless you are going to use H.264 and you buy a graphics card with some chest hair. Personally I would concentrate on the CPU, unless you also like gaming.
With my Athlon II x4 640, I do see a huge improvement with MPEG-2 using TMPGenc Xpress or CCE, but I rarely use MPEG-2 these days. x264 benefits the most, with every core maxed out to 100%, a great improvement over my old dual core.
Current versions of XviD and DivX don't seem to make full use of all 4 cores , the same applies to XviD/MPEG-4 using FFmpeg and Mencoder. They are a little faster, but not as fast as one would expect from having the 2 extra cores, quite disappointing really.
As you can see from the screen shot, with FFmpeg/libxvid encoding at the highest settings and using 4 threads, only about 50% of the CPU is being used.Last edited by mh2360; 2nd Feb 2011 at 09:23.
cpu vs gpu for video rendering with i5 460m 2.53 ghz
By Edgarke16 in forum Software PlayingReplies: 6Last Post: 3rd Jan 2012, 06:43 -
FAST RENDERING of Final Cut Studio Pro and After Effects files.
By Kevin Whelan in forum MacReplies: 3Last Post: 24th Aug 2011, 12:40 -
How fast will a Intel 2500k processor convert 4 hours of avi to DVD
By johnharlin in forum Video ConversionReplies: 7Last Post: 9th Jul 2011, 22:01 -
Using GPU fpr video encoding?
By wiseant in forum Video ConversionReplies: 2Last Post: 31st Dec 2008, 20:00 -
good laptop for video rendering, editing, etc
By husman in forum ComputerReplies: 1Last Post: 16th Jul 2008, 18:07
