    Nov 2007
    somewhere beautiful
    Can someone recommend a good program for joining (merge) HD m2ts files? I record with Sony HDR-CX115 HD camera, but since I wanted to do menu and pop up menu in Adobe Encore I thought all of them combined into one file because I have a 30 video clips. I tried TsMuxer but I get desync of audio and video.
    Nov 2007
    somewhere beautiful
    This is info about one video file.
    General
    Complete name : F:\marina i mladen\30.1.2011\20110129212402.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 1.85 GiB
    Duration : 11mn 49s
    Overall bit rate : 22.4 Mbps
    Maximum Overall bit rate : 24.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Duration : 11mn 49s
    Bit rate : 21.2 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.410
    Stream size : 1.75 GiB (95%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 11mn 49s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Video delay : -80ms
    Stream size : 21.6 MiB (1%)
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Duration : 11mn 48s
    Video delay : -80ms
  3. Edit: Try TSDemux AVCHD/Blu-Ray M2TS stream demultiplexer. Joins and demuxes HDMV M2TS/MTS (MPEG-2 transport stream) or TS (transport stream) files to Elementary streams.
    https://www.videohelp.com/tools/tsDemux
