I have a PMP which says that "Display: 4.3" 480 x 272 TFT WQVGA, Widescreen, 16m Colors". It also says that it will support "AVI: Resolution up to 1280x720, RM:1280x720, 30 F/S" If I want to make a video that can make full use of the screen. Deos it mean that I can specify up to 1280X720 but not smaller than 480X272 as the resolution in the software that builds the video ? I think I need some basic understanding on the relationship between the screen resolution and the actual video resolution used in encoding the video. Can anyone help ?
If the resolution of the screen is 480 x 272, then any video with a higher resolution will be downscaled to fit the screen.
If you plan to make videos exclusively for use with this player, then I would encode them at 480x272, anything higher is a waste of storage space. -
Typically, devices scale, up or down, from the source resolution to the display resolution.
Thanks,
Is 480x272 considered as HD for a 4.3" device ? I am just wondering what resolution should the device has in order to get a true HD video quality. This is for my education when I buy my next PMP. -
At 4.3 inches 480 x 272 is more than adequate, and done correctly videos should look great.
Not so long ago we were all watching VCDs with a resolution of 352x240 on large screen TVs.
Will look adequate because of viewing distance and angle but is not HD or even DVD resolution.
If your 4.3" display was HD resolution, you would need to view inside 8 inches to see a difference vs SD.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
PC to TV screen resolution question
By majel in forum DVB / IPTVReplies: 15Last Post: 28th Jun 2010, 10:22 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38 -
How can I LOWER rsolution of a *.jpeg image
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2008, 11:04 -
screen resolution avi to dvd?
By drwho in forum Video ConversionReplies: 3Last Post: 14th May 2008, 18:25
