I have one hd toshiba tv hooked to cable and I get hd programming as channel 5-1, 11-1 etc. with compatible remote. I also have a hd ready tv. What do I need to hook between cable and the tv to get hd? It needs to have its own remote to be able to get the channels 5-1, 11-1 etc.
Results 1 to 24 of 24
http://www.kiva.org/about -
I guess I should have added that I do not have a cable box in my house. The sets pick up programming off the initial cable. What do I need to make my second (HD ready) set do the same?
You need something with a clear QAM tuner. For example:
http://www.amazon.com/Kworld-HDmi-External-Digital-Tuner/dp/B002RL8I2W
http://www.amazon.com/gp/product/B000XY6N5Y/ -
Thanks, basically what I really want is something I can insert between my existing cable and the cable connection on the TV that will allow me to get the HD channels with HD quality on my supposedly HD ready "Tatung 32" TV, that I already get on my Toshiba HDTV. I realize that it will also have to have a remote that gets 5-1, 11-1 etc. It has HDMI connection, pic in pic and all the goodies on the current remote but will not tune in the HD channels.
Thanks again,
Ric -
It won't connect to the coax in. You have two HD inputs, analog component and DVI. Nothing I can find indicates the DVI input is HDCP compliant. Check your manual. That leaves analog component.
For cable you need an HD cable box. Cable in and analog component out to TV.
For over the air reception an ATSC tuner will work.
http://www.amazon.com/Samsung-DTBH260F-HDTV-Terrestrial-Receiver/dp/B000JV6TQY/ref=sr_...6454612&sr=8-3
There may be a standalone ATSC/QAM tuner (QAM for cable). This might work into your DVI port. If it does, it will just tune the unencrypted QAM channels.
http://www.amazon.com/Kworld-HDmi-External-Digital-Tuner/dp/B002RL8I2W/ref=sr_1_1?ie=U...6454831&sr=8-1Recommends: Kiva.org - Loans that change lives.
never recommend Samsung DTBH260F to anyone even my worst enemies.if u do be sure to buy a full bag of capacitors
I bought a used DirectTV box from ebay for $20-$30 for my HD ready tv. There are tons of them. I used an OTA antenna, but I guess the cable would work for a few channels. I received good HD signal from half dozen stations. You don't have to have DirectTV for the tuner to work with over the air stations.
I love children, girl children... about 16-40
W.C. Fields -
W.C. Fields -
W.C. Fields -
You're obviously more up on it than I am. I just noticed it has 3 coaxial cable input labeled Cable In, Satellite In & Air In with a DTV input switch, so I thought it might help him. As I said, I've only used it for OTA. I thought "HD ready" tvs didn't have tuners, my old Olivo tv didn't have a tuner, that's what I used this for.
W.C. Fields -
It would need to have a QAM tuner to get HD from cable.
W.C. Fields -
Sorry, forgot a click.....
HD local stations via a Clear QAM tuner
#1 25 Oct 2005 @ 18:01
diabolosVisit user's personal pageSend private message to this user
Senior Member
I have been doing some research into QAM (256 QAM/Clear QAM) tuners. It seems that it is possible to recieve HD local channels, and any digital channels for that matter that are unscrambled, by simply using a 256 QAM tuner without the need for a "Digital Cable" subscription or box (or cable-card). I just wanted to know if anyone here at AD has any knowlege on the subject. I hope this is true because I wouldn't mind paying for basic cable service if I could get my local channels in HD like I can now over-the-air (for free)!
People could get all of these channels with "Basic/Standard Cable" service through Time Warner Cable (TWC).
Thankz,
Ced -
Is the feature Internet stream ready same as Wi-Fi ready on the Blu-ray DVD
By coody in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Nov 2010, 20:09 -
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 13:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 16:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 14:50
