Hi Folks
I am going to test to burn a DVD-R doublesided 9.4Gb disc with a movie I have. The movie is presently in MPEG2 SVCD format. It's on 4 files and I will burn two files in sequence on one side of the disc and the other two files on the other side.
The stats for these files are:
Mux Rate: 2788800 bits/sec
Type: SVCD
Video Standard: NTSC
Frames/Second: 29.97
Resolution: 480x480
Audio sample rate: 44100 samples/sec
Bits per sample: 16
Channels: 2
Codec: MPEG1 L2
I am intending to use Roxio VideoPack 5 for this project and the goal is to make the disc playable on a Philips DVD762 stand-alone.
But since the discs are pretty expensive I want some general tips from you guys n' gals.
Is there anything in particular I should have in mind or does VideoPack do the job properly?
Is there another program I should consider?
regards
Kristian
