  1. Hi,
    I have bought a Canon HF S200, and I need some help because I'm a beginner
    - For the Frame Rate I have put 50I instead of PF 25 is it a good choice?
    - I can't change in Image Effects to Vivid
  2. Sorry i have another question:
    when I choose Recording Mode -> MXP i have this message " Cannot create AVCHD discs that include scenes recorded in this recording mode. " what does mean that?
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    50i should be your standard setting for hand held (50 motion samples per second, interlace video).
    PF25 is progressive at half motion rate (25 motion samples per second). This setting will appear more jumpy so cam should be tripod mounted with minimal pan/zoom.
    http://www.kiva.org/about
  4. Member edDV's Avatar
    Mar 2004
    Show the manual pages for the recording modes. They are saying that mode is incompatible with Blu-Ray.
  5. Thank you, I have tried a lot of setting but i still don't have a very good quality, I'm looking for this result:
    http://www.youtube.com/watch?v=WevPDRHBMrA
  6. can you describe what's wrong with your "quality" ? or post a video ?
  7. Member edDV's Avatar
    Mar 2004
    Note that that guy was using a tripod (not the best fluid head) and mostly focus was manual.
    MPX is your highest recording bit rate per the manual. Start with 1080i before experimenting with progressive. Progressive needs a tripod.
  8. Thank you, i have tried today ( with MXP - 50i - tripod - Image Effects Vivid ) and it's OK I'm happy with the result.
    Another question, what's the best way to convert the MTS file? I used Wondershare Video Converter Platinum and iSkysoft but the render is not as good as the original!
