Okay, I have a Samsung HT-Z310 Home Theater System. It doesn't always read discs, as it sometimes gives "Disc Error" after trying to load after several minutes. I cleaned the laser and found that the drive doesn't always spin the disc after it's put in. Aside from getting this unit serviced, is there anything else I can do? Anyone know about how much would it cost to service?
It Started In Texas
Service would be your only option. Prices vary from shop to shop. Check with your local shops, most will apply the inspection fee to any repairs that may be needed. Personally, it's cheaper to simply get a replacement player.
Google is your Friend -
It Started In Texas
Camcorder doesn't read SD card!
By Dawood1987 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 14th Apr 2014, 07:25 -
Samsung HT-Z310 and Hi Res Xvid / Divx
By TooterDon in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2008, 18:17 -
Need region hack for Samsung HT Z310
By pesoboiem in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Sep 2008, 21:40 -
Any Way To Get XP To Read UDF2.60 Discs?
By Anakin in forum Authoring (DVD)Replies: 3Last Post: 13th Aug 2008, 19:52 -
Womble doesn't recognise avi audio from my Samsung Digimax
By keveen in forum AudioReplies: 2Last Post: 26th Jul 2007, 17:24
