Hi all,
I'm trying to render a DVCPRO HD source footage using x264 to bluray compatible 720p24 (23.976 really).
My problem is that I have the pixel aspect ratio all wrong and can't work out what it needs to be
Here is the MediaInfo of the DVCPRO HD footage
Here's the command line I used on x264 hoping to get 720p23.976Code:GeneralComplete name : xxxx.mov Format : MPEG-4 Format_Commercial_IfAny : DVCPRO HD Format profile : QuickTime Codec ID : qt File size : 8.03 GiB Duration : 24mn 10s Overall bit rate : 47.6 Mbps Encoded date : UTC 2011-01-25 06:35:53 Tagged date : UTC 2011-01-27 04:11:46 Writing library : Apple QuickTime Media/UUID : E92ED4A8-3767-4D90-A351-171172394D36VideoID : 1 Format : DV Format_Commercial_IfAny : DVCPRO HD Codec ID : dvhp Duration : 24mn 10s Bit rate mode : Variable Bit rate : 46.0 Mbps Maximum bit rate : 97.7 Mbps Width : 936 pixels Original width : 960 pixels Height : 702 pixels Original height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Original frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 10 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 2.922 Stream size : 7.77 GiB (97%) Language : English Encoded date : UTC 2011-01-25 06:35:53 Tagged date : UTC 2011-01-25 06:50:03AudioID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 24mn 10s Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 266 MiB (3%) Language : English Encoded date : UTC 2011-01-25 06:35:53 Tagged date : UTC 2011-01-25 06:50:03MenuID : 3 Language : English Encoded date : UTC 2011-01-25 06:50:03 Tagged date : UTC 2011-01-25 06:50:03
First off, is my "resize" correct?Code:x264 --bitrate 20000 --preset veryslow --tune film --weightp 0 --bframes 3 --nal-hrd vbr --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 30 --b-pyramid strict --slices 4 --fake-interlaced --pic-struct --aud --colorprim bt709 --transfer bt709 --colormatrix bt709 --sar 1:1 --force-cfr --pass 1 --vf resize:1280,720 xxxx.mov -o out.264 lavf [info]: 960x720i 0:1 @ 60000/1001 fps (cfr) resize [info]: resizing to 1280x720 resize [warning]: converting from yuv422p to yuv420p x264 [warning]: input appears to be interlaced, enabling bff interlaced mode. If you want otherwise, use --no-interlaced or --tff x264 [info]: using SAR=3/4 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile Main, level 4.1 x264 [info]: final ratefactor: 10.09 aborted at input frame 51, output frame 0
Second, I think the problem is the SAR. What should it be? (I tried 1:1, 4:3, 16:9) and the first comes out narrow and the later two very very wide in Windows Media Player.
Third, should I have "--tff" ( i get that as a warning )?
Fourth, is my output frame rate going to be correct?
thanks for the help
rallymax.
If you've resized to 1280x720 , then sar should be 1:1
Native 720p DVCProHD is 960x720 , so the sar would be 4:3, because 16/9 = 960x720 x 4/3 . But that isn't compatible with blu-ray , so you should be resizing to 1280x720 with square pixels
The problem is it's detecting it as interlaced 60i . This isn't going to work for you. You could try specifying different demuxer like ffms vs. lavc, but it will probably still "see" it as interlaced 60i
If it's 23.976 footage as your title suggests, you're going to have to IVTC somewhere, e.g. use avisynth ; I don't think any of the x264 filtering patches have IVTC built in
x264 command line for max quality within Bluray spec?
By Asterra in forum Video ConversionReplies: 5Last Post: 5th Apr 2012, 16:22 -
x264 Mediainfo to MeGUI x264 Settings
By shagratt71 in forum Video ConversionReplies: 0Last Post: 1st Jan 2012, 05:59 -
LG BD390 Bluray Player w mkv/x264 support - Questions answered
By andor1999 in forum DVD & Blu-ray PlayersReplies: 17Last Post: 31st Oct 2010, 12:02 -
backup bluray -> x264 to bdisc
By Dragonfiii in forum Software PlayingReplies: 0Last Post: 8th Mar 2010, 17:52 -
HDDVD/BluRay and x264+Matroska?
By BIOHazard87 in forum Newbie / General discussionsReplies: 10Last Post: 3rd Nov 2007, 05:41
