I want to start capturing AVI files at maximum quality which I will with convert to MPEG2 with TMPEGenc and burn to DVD. I will be capturing PAL video from live broadcasts and also S-VHS tapes.
My question is, which settings should I use (resolution, audio, etc.)? I own an ATI All In Wonder 128 ifitmakes any difference.
I would normally capture audio at 44.1KHz but I heard somewhere that DVDs use 48 KHz, so I don't want to get the wrong audio frequency!
Also, I'm a little unsure about interlacing. I don't want to lose any interlace information when I capture/convert to mpeg2. How do I make sure there's no merging of frames and I get the full 50fps?
Finally, I'm not very clued up about aspect ratios. Do I need to use one resolution for 16:9 and another fo 4:3, or do both these aspect ratios use the same resolution only stretched out?
Please help!
Another question I have is how do I capture AVI at full resolution. I can't seem to find a 720x576 setting whenI select AVI mode. Isn't 720x576 full resoltuon?
Are my capture settings ok ?
By smartel in forum Capturing and VCRReplies: 107Last Post: 29th Mar 2012, 11:13 -
Video Capture Settings.
By Green_Tape in forum Capturing and VCRReplies: 1Last Post: 4th Oct 2011, 23:37 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Capture Settings for Divix
By Nosey249 in forum Capturing and VCRReplies: 2Last Post: 13th Feb 2010, 18:45 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 21:05
