I'm using Visual Hub as well as FFMPEGX for online video encoding. I've downloaded Theora because it's said to be an add on to configure into both of these programs for output .ogg video files format for HTML5 publishing. How do I install ffmpeg2theora into FFMPEGX v0.0.9x? And how do I install THEORA-v1.1.1 into Visual Hub v.1.3.1?
I realize Visual Hub is nolonger supported; and is being developed under the name ReduxEncoder
Smitty
B'klyn, NY
OSX 10.4.11
PPC G4
	I moved your post as the Glossary is just for information/definitions and I doubt you will get replies there.
 Moderator redwudz
 And welcome to our forums.
	Who did say that?
 nope, ffmpeg2theora is an app (a command line app to be more accurate)How do I install ffmpeg2theora into
 nope too (almost the same answer: theora is a library for developpers and a command line tool for final user, you can't incorporate it in an app)And how do I install THEORA-v1.1.1 into
 byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
	try VLC, believe it or not
 It was the best ap I found to make an .ogg
	Ok, since my understanding was wrong; perhaps I should ask how to import video container formats into Visual Hub and FFmpegx? I’m specifically interested in .ogg and .3gp container formats. According to Visual Hub's user guide this is possible. Yet I don’t see instructions for implementation. Is this something only a Developer can do?
 FYI: User Guide/page 43
 Visual Hub version 1.3.1
	Ok, I did find this video demo for using ffmpeg2theora implemented the from command line to covert a video to the .ogg file format.
  Can't install binaries for ffmpegX 0.0.9yBy kostas1969 in forum ffmpegX general discussionReplies: 2Last Post: 21st Feb 2012, 13:14
  Cannot Install ffmpegXBy FunkyBeccaBecca in forum ffmpegX general discussionReplies: 1Last Post: 14th Oct 2011, 12:26
  How to install ffmpegX on 10.6 without Rosetta?By t1000 in forum MacReplies: 7Last Post: 11th Jul 2010, 19:04
  Can't Install .rm Support In ffmpegXBy bowjest in forum ffmpegX general discussionReplies: 19Last Post: 31st Jan 2009, 23:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
