    May 2007
    I am looking for help on using clipfix, which is a plug-in for audacity. It fixes some audio files that have clipping problems. i have looked on the net, but cannot find any help file. Please advise.
    Thanks!
  2. Member brassplyer's Avatar
    Apr 2008
    Good place to look might be this forum for Audacity
    http://forum.audacityteam.org/
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    If you look in the clipfix.ny file, you see some comments at the top:
    ;name "Clip Fix..."
    ;action "Reconstructing clips..."
    ;info "Designed and implemented by Benjamin Schwartz.
    Clip Fix attempts to reconstruct clipped regions by interpolating the lost signal. Before use, reduce amplification by 10 dB to give room for the reconstruction. 'Threshold' is how close to the maximum sample magnitude any sample must be to be considered clipped. If processing is slow, select only a few seconds of clipped audio at a time."
    And there is some discussion here.
    Jul 2009
    Spain
    No need to go that far, the same text appears in the dialog box that pops up when you apply ClipFix.
