hello, i have a real noob question.
i have dv-avi files from a minidv camcroder which i'd like to burn to a DVD, and would like to have the best possible video quality for the DVD. i don't worry as much about the audio though, and was happy with the it when i burned a DVD on the default AVStoDVD settings.
what are the settings that i should pick in AVStoDVD? do i change them in preferences or in title settings or both or somewhere else? im talking about things like video bitrate and all the other stuff that applies. but please dont just say set video to this bitrate or that bitrate... please mention where in the program i gotta do that cause it looks like there are many places to do it and im confused.
In General, the program picks the best settings based on your input resolution and run-time in hours and minutes.
Try to limit the source run-time to three hours or less. (two hours is better)
Before you start your project, enter the preferences and choose NTSC or PAL depending on your
desired result. Save it as default.
Open your source file. Edit the title, choose the video tab and pick HCenc 2-pass. Encode the project.
That's all you have to do. -
Sometimes DV recordings may show some grain, mainly when taken with poor natural light. The effect is even more evident after mpeg2 conversion.
In those cases you can somehow reduce the grain effect by using a high-frequency denoise filter, like HQDN3D. Go to 'Title Edit'/'AviSynth' and toggle on 'HQDN3D'. Use default strength to see if it improves and then adjust it to further improve.
Bye -
HI Mr_C,
regarding the mscomctl.ocx included in the no_install package.
Attempts to register it fail because of the existence of an older version in \windows\system32 (XP SP3)
After unregistering the system version, renaming it, and copying your new version to \widows\systerm32,
I can now register the new version. Your program seems to work OK on the old version; is the new version
really necessary ? For example, my old version is 6.1.97.82, while your new version is 6.1.97.86
Perhaps there is an update to a component I haven't installed.
Are my AVStoDVD settings wrong?
By ehunter in forum Video ConversionReplies: 13Last Post: 17th May 2017, 22:32 -
How can I make subtitles hardcoded and change font? (avstodvd)
By striker9 in forum SubtitleReplies: 6Last Post: 1st Sep 2010, 02:32 -
AVStoDVD: How do I make default settings for all files to aspect ratio 4:3?
By Heyjoojoo in forum Authoring (DVD)Replies: 8Last Post: 30th Aug 2010, 22:49 -
AVStoDVD Best Settings?
By BlazinAsian in forum Authoring (DVD)Replies: 4Last Post: 5th Mar 2009, 16:56 -
Recommended Min Quality Video settings for CamStudio
By Firewire60 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 07:11
