    Dec 2008
    So I installed the latest huffyuv codec to see what the fuss was all about and it doesn't appear in my compression list.
    I see nothing and I even set the custom format to YUY2.
    Any advice?
  2. 32bit or 64bit ? huffyuv ? what about vdub? everything has to match 32-bit for 32-bit, 64-bit for 64-bit
    Dec 2008
    Ok, I'm an idiot and I'm glad the fix was that simple. I didn't even know there WAS a 64-bit version of huffyuv. But I downloaded that and the 64-bit vdub and it works perfectly. I'll never go back to Xvid again!
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What makes you think Huffyuv and Xvid are the least bit comparable?
    Dec 2008
    I wasn't comparing them. I was extolling the virtues of huffyuv. Also I hadn't heard of huffyuv before.
  6. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    The "ffdshow codec" in VirtualDub has both Xvid and Huffy and a plethora of other delights.
    I hate VHS. I always did.
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    At around 40GB per hour of HuffyUV....HuffyUV is more of an intermediate solution rather than a "final product" solution like Xvid or even MPEG2. Nobody is sharing HuffyUV files via the internet just like nobody is using Xvid compression out of an editor to be used in another editor.
  8. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    I agree. Xvid, DivX, MPEG-2, H.264, WMV, and other similars, are designed to be deliverable formats, and certainly not in the same league as HuffYUV, which is meant to be an acquisition or intermediary format (depending) in a huge majority of cases.
