hey plz help me!
i got sum movies off my mate in avi format, they ones that are in one full movie play but the ones that are in two parts only have sound and no picture. how can i fix this!
this is with wmp
same prob with r1
doesnt wk with divx
:x :x
Sounds like a Codec problem, I suggest you install DivX Codec on your PC and see if that helps out.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
