Hi
How do ATI AIW "Soap Video Filter" and JVC DR.... DVD recorder's chroma noise filters compare and how do they combine (if any JVC DVD recorder with good quality chroma filter has passthrough option at all)?
Does using a JVC SVHS deck with TBC and DigiPure mean that I don't need to use those chroma noise filters from JVC DVD decks? (How do they combine?)
Are there any other chroma noise filtering alternatives in hardware (signal) sense?
Can the "softening effect" that TBC1000 does be at least "lightly cancelled" by using a detailer?
Many thanks
Compare? They can't, not head-to-head, as they operate differently.
VideoSoap doesn't do chroma NR.
S-VHS VCR can't always have TBC in use on all tapes.
And there's a benefit from two-pass chroma NR.
The softening discussed by others on TBC-1000 is unproven to date, and varies by unit.
If you do see it, yes, it can possibly be countered by sharpening tools.
Be sure to follow my posts here at VH and over at The Digital FAQ (as well as others there).
These topics have been discussed many times over the years.Want my help? Ask here! (not via PM!)
Can't set Comb Filter to 3D on ATI 750
By HDClown in forum Capturing and VCRReplies: 6Last Post: 20th Sep 2013, 17:25 -
Using VirtualDub's "capture filter" proc amp
By sanlyn in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2012, 08:13 -
Microsoft WST Codec filter & Hauppauge Remote?
By amdk62 in forum Newbie / General discussionsReplies: 6Last Post: 18th Dec 2007, 12:21 -
ACDsee Filter&VDUB
By mv0930 in forum Newbie / General discussionsReplies: 0Last Post: 4th Sep 2007, 13:27 -
AT&T Announces Plans to Filter Copyright Content
By BJ_M in forum Off topicReplies: 1Last Post: 13th Jun 2007, 22:45
