Hi
I am new to svcd as you will tell.I have played with .avi a little.
but i have just used dvd2svcd and encoded with TMPGEnc . In the movie folder
that my encoded files are i have these 4 movie clip files.
bbmpeg muxed file00 131mb
encode audio 1 122mb
change cd pictu re.bmp 20.4kb
some mpv files,avs files , ac3file 285mb
and a bbmpeg muxed file mpgoo 734mb.
I thought i was looking for bin and cue files????
any idea what i have done wrong? if i havent what the hell do i do now![]()
Thanks DAZA
Results 1 to 11 of 11
Hi
you did not do anything wrong!
but:
you can specify don't remove any temp files (default is off)
the muxed file is the movie (part 0 for the first cd 1 for the second if any)
If you use/check vcdimager then dvd2svcd creates the bin/cue files for you
You better use that so you only have to select the cue file in your burning software (use Nero 5.5+) and youre off!
Also using the vcdimager option you will have selectable chapters (like the chapters on you original dvd)
also always use 80min cdrom sou you will around 60 mb more data on your disc
(you can store 800mb on one 80 min cd, thats 100mb more than a normal windows data cdrom)
good luck
Bart -
Thanks for your help
i see where to select vcd imager.Does this mean i have to encode again
with this option on??????
if not what do i do from here???
Thanks DAZA -
one more thing i ghess i should have made this movie 2 cds??? i used default under bitrate. To select 2cds 800mb etc how is this done?
Thanks DAZA
Hi,
your 2 questions:
1) You can burn the already converted mpg file you have, saying 'muxed' in the name using Nero 5.5+ (or a equivalent burn prog) and select the Super Video CD template at the opening (wizard). Drag your mpg file from the file explorer window into the cd window
Nero checks the file and ignore warning (if any) about audio being 48khz when it should be 44.1khz because most players will accept it
(default is convert to 44.1 but this just takes more time to encode)
If you want the svcd chapter version using the vcdimager option you better convert the dvd again (or you can use the vcdimage gui and define the chapters yourself but i would not try that at this point)
2)
I you used the defaults on the bitrate tab
then any dvd should result into at least 2 cd's
in the cd file size combo on the bitrate tab select 800mb (or just type the size you want)
on the left side of this combo you can specify between which movie duration interval (say 90-120 min) how many cd's have to be used
(Pearl Harbor is almost 3 hours and ONLY then i use 3 cd's)
good luck
Bart
bartkorn@hotmail.com -
Thanks mate for your help the muxed file is only 734meg
so how can this be 2cds????
do you have to split bigger files?
if not how does the burning progess work?
thanks for you time
DAZA
Hey I thought I already said the burning proces, like using Nero 5.5+ select Super Video CD template and drag the (734mb) Mpg file into the cd composition window
And BURN
The file will be checked and if you didn't change to much settings it will be a full compliant but I said not to worry about the 48 vs 44.1 khz difference
If you did not change any settings and you converted a 'normal' DVD
it should give 2 files hence two cd's
me I never had movies on one file/cds
R u sure there was only one muxed file in your directory???
which movie was it? or at least how long?
stick to a maximum of 60 min per 80min cdr
btw, a good (but not better) equivalent for Nero is WinOnCD
good luck
Bart -
Thanks cornsoft2002
All came out good yes i did only have 1 muxed file it was a john forgerty
live consert so maybe not as long as some movies
thats why 1 file??? it looks good
so whats the best way to do it the way i have done it now or select vcdimager as u said and get bin and cue files???
Thanks again
DAZA -
if the maximum bitrate is larger than svcd standard (ie 3500) can i still fit 800 megs on 80 min cd?
i am using one of latest version of nero and it doesnt seem to compress the 800 megs. but when i used bitrate 2500 i can fit 800 megs on 80 min cd. Strange
thanks -
avg bitrate determines filesize(note there is no avg bitrate for cq_vbr)
sorri for going over this so many times but what i meant was that my final mpeg2 file was 790megs. but it doesn't fit on 80 min cd.
any reason for that?
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
