Hi,
Just encoded .avi file with .srt subs to DVD but when I try to watch the movie in preview there is no picure or subtitles, only sound. Any suggestions on what I did wrong?
Greetings
Test #1: Does the AVI play in QuickTime? (I think it will not show video.)
The DVD mpeg2enc preset defaults to decoding with QuickTime. This means that ffmpegX "asks" QuickTime to read the source file. If QuickTime fails to decode the video, then ffmpegX will fail to encode video in the output file, perhaps as just black.
Solutions (pick one):
• Install Perian. Perian will help QuickTime decode many formats and video codecs that QT wasn't able to decode without it. (Perian also has hard-subbing ability of its own, so disable that feature if you want ffmpegX to handle soft sub on the output DVD.)
• Use a different decoder. The DVD mpeg2enc preset allows setting a different decoder in the Options tab. Set the Decode with mplayer checkbox to let mplayer read the source file. (Using mplayer decoding will result in hard subtiles.)
• Use a different decoder. The DVD mpeg2enc preset allows setting a different decoder in the Options tab. De-select both Decode with QuickTime and Decode with mplayer to have ffmpegX use built-in ffmpeg to read the source file.
The soft subtitles on DVD encoded by ffmpegX may be set to "not show" by default. Use your remote or Console to turn them on.
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
How do I capture a picture frame from a movie and make it into a picture?
By Hawkredtail in forum Capturing and VCRReplies: 7Last Post: 8th Sep 2007, 18:44
