I own a Samsung UN55C6500 LED TV and I've been playing MKVs on my TV through my Hard drive hooked up to the tv itself.
What I've noticed is that for some movies where their is foreign dialogue where I would expect the subtitles to activate, doesn't happen. Chances are I am deleting the files associated with the subtitles when transferring the MKVs from the download folder to the hard drive. I've read that I can download a SRT file from say subtitles.org and then encode them on to the MKV using MKVToolNix - mkvmergegui.
I think I am doing things right but am still having trouble with this. I picked the MKV as input and the SRT (which I gave the same name as the MKV) as inputs, choose yes under Forced Track Flag option for subtitle.
After muxing the file setup looks like the image I posted in the following link:
http://s1122.photobucket.com/albums/l522/theproman23/?action=view¤t=MKVSetup.jpg
The subtitles seem to be there. I put the MKV and SRT in the same folder and the subtitles won't activate like I expected.
Any help on this would be great!! Thank you so much!
Does it even support external subtitles? Does it work with an avi and srt for example?
I own a Samsung TV as well and when i play mkv with sub through its' media play function, the sub must be saved on your external HDD separately with the same name as your mkv file in the same folder :
example :
test.mkv
test.srt
It will play fine...
Oken,
I've actually done that myself. I put the srt file in the same folder as the MKV and named it the same exact name as the MKV. I'll have to check the settings again when I get home.
When you follow this procedure do you have to run both files through MKVToolNix - mkvmergegui?
I am looking to have the MKV know when to show subtitles, for example when there is foreign dialogue. I don't want to have to manually turn on the subtitles and manually turn them off for the english parts. -
The only way to display srt sub is to save one sub file with the mkv file (with same name) on your external HDD hooked on your Samsung UN55C650.
If you have a MKV muxed with srt subs (check with mediainfo) than use MKVToolnix to demux them.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Preserving only "forced" subtitles from .sup file
By cjbrown80 in forum SubtitleReplies: 3Last Post: 15th Feb 2011, 14:57 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Getting subtitled MKVs upstairs to my HDTV downstairs
By EwanG in forum Media Center PC / MediaCentersReplies: 7Last Post: 18th Jun 2009, 10:29
