This is my first time here, so sorry if I am in the wrong place.![]()
I have a DVD which is no longer made. I have an APEX-5131 player. How can I make a back-up VHS videotape of this DVD for my own personal use ?
Can I just use the cables from the APEX nd put it into my Panasonic VHS VCR ? A friend said I need to change a chip inside this APEX player.
Thank you.
Hi i have never done this with dvd but i have done it with avi files
as long as you have the sound and the dvd source running through your vhs player to the tv run through the vhs channals and see if you see the pic from the dvd if so click record if this dont work ripp the dvd and encode it to .avi or vcd or svcd and theres your copy
easy ah -
i saw a gizmo that you attach your dvd player to first then to your vcr , its supposed to remove the macrovision protection signal from the dvd thus enabeling you to record , it was on a web site somewhere soz i dont have the address , but i think it cost about 100 bucks
Netpeace -
Do a search at google.com on your player - there are lot's of APEX sites out there. They can let you know if you need a chip, or it could just be some commands on the remote, or (as in my case-Apex 660) a file I burned to a cd and just put in, and the player updated itself.
What your trying to find out is how to turn the Macrovision off in your player. Then you can just plug into your VCR and hit record. -
Its called a video clarifier. A little box you run the video aux through, and it clears macrovision. Works brilliantly for vhs to vhs dubbing, but I've got varied results recording dvds to vhs. Sometimes it works, sometimes it doesn't. Like the above post suggested, see if your apex has a way to turn off macro.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Question about transferring a MAcrovisioned VHS tape to DVD
By goodsmartman in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Sep 2011, 20:21 -
Legality of commercial vhs tape to DVD for personal use
By wiseant in forum Newbie / General discussionsReplies: 18Last Post: 26th Sep 2010, 18:20 -
making a DVD from an old Video camera tape
By oreocharlie in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2007, 13:39 -
old VHS tape making vcr heads dirty
By abbymat in forum RestorationReplies: 7Last Post: 16th Aug 2007, 06:33
