Hi guys again,
I have a update of my problem...so I did installed an older version of MKVmerge, and it works on my blu-ray player...but the subtitle still doesn't come out even I have merged it into the video...can anyone tells me what the problem is, and how i can fix it? Big thanks...
Hi guys,
I have a LG blu-ray player BX580, so recently I am planning to play some mkv files on it, but it doesn't work.
So here is my problem,
At first I have a mkv files with flac audio, due to the reason that the blu-ray player doesn't support flac fomat, so I try to convert the whole mkv file and change the audio format to mp3. The software I use is Xilisoft Ultimate Video Converter. So after I converting the file, I play it on the blu-ray player, and it works absolutely fine, but another problem comes out, that's the subtitle. After converting the mkv file, the subtitle is gone.So next I use MKVExtract GUI to extract the subtitle in the original mkv file, and try to merge it into the new mkv file using MKVMerge GUI. The process goes successfully. And by the time I thought there wasn't any problem, I was wrong...
So I try to play the converted file with subtitle on the blu-ray player, but the file cannot be played...and now I am totally exhausted...I really need some help from you guys. Thank you very much...
	pherhaps you need to force Header Compression to none, new versions of MKVToolnix has this option set by default which is incompatible with some devices
 can you upload a small sample of that MKV+FLAC and post here ?
	This is the sample of the MKV+FLAC mkv file. Anyway I don't really know how to force Header Compression to none...could you teach me to do it??
	In mkvmergegui under file->options Disable header removal compression for audio and video track by default. Then open the mkv and make a new mkv.
	Thank you very much! Actually I have just taken a look on the MKVToolnix description page, and I found out other people has similar problem as me, and their solution is to use the older version of the program. I think I will try that also~ but really a big thanks!
	I'm not sure bout your lg player but mine doesn't support FLAC audio you need AAC so converting that should do the trick and I suggest you study the manual as it says what formats in what container is supported.
 open avidemux : set video to copy (no encode means no quality loss) set audio to aac 128kbps should do.
 ha didn't read the post properly.
  Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray playerBy brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15
  Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35
  Copyed Blu ray won't play in blu ray playerBy gweedow in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 15:58
  What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 23:04
  My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray DiscBy showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 13:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
