Dear friends,
i recently bought a DVB-T MPEG4 decoder that also doubles as a PVR.
It records in .ts format.
I was wandering if there is a free tool that I could edit those .ts media files and cut out commercials.
Thank you in advance for any replies...
AVIDEMUX will do what you want. Open your .ts file, mark the start of the commercial break with the 'A' & the end of the commercial break with the 'B', then go 'edit-cut'. Repeat for each segment you with to remove, set your preferred output format/container then 'file-save-save video'.
You can leave audio & video set to 'copy' (which is the quickest option) or you can take the opportunity to export to a smaller filesize format such as .avi by setting video to MPEG-4 ASP (xvid), audio to AC3, MP3 etc. & container to AVI.
The way I do it now is to convert .ts to .avi first using MCE Buddy, use AVIDEMUX to cut the commercials, leave audio & video set to 'copy' and re-save the file as an .avi. Perfect lip-sync & much smaller file size.
Hope this helps! -
Thank you all very much for the replies. I will give a quick trial on all three tools proposed here and pick the one I find more flexible and reliable. Thanks once more for all the support.
What Laptop is adequate for editing with Hauppauge HD PVR?
By Quivox in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2010, 18:26 -
Accurately editing commercials from HD PVR h.264 .ts files
By finallygreen in forum Video ConversionReplies: 10Last Post: 28th Oct 2009, 15:14 -
HD PVR HAUPPAUGE probs editing any of the formats and keeping audio intact
By chuffy in forum EditingReplies: 2Last Post: 5th Sep 2009, 18:32 -
Capturing and editing game video w/ HD-PVR
By helloitsdan in forum Capturing and VCRReplies: 8Last Post: 29th Jul 2009, 11:47 -
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 09:26
