My apologies if I am posting in the wrong section . . . I'm admittedly a novice and am beyond confused over this.
I have been using Ulead VIdeoStudio 10 SE (packaged with EasyCap device) to capture video from a wireless surveillance camera. I am attempting to capture for approximately 14 hours continuously, which in raw avi is generating huge files.
To handle this, I installed a 1TB drive last night to dump the file to. When I came home this morning, I found a file "uvs110125-002.AVI" in my storage folder, and Ulead acted odd as I logged on. Anyway, the file is over 673GB in size which seemed appropriate given the shorter captures I've done without incident. But when I tried to play the file, it only played for 4 seconds, supposedly complete!
The only clue I see to the issue is that there are two clips listed at the top of Ulead--"uvs110124-002.AVI" and "uvs110125-002.AVI". However, when I click on the "124" file, Ulead throws up the error "Original file [I:\Store\VC\uvs110124-002.AVI] doesn't exist." And indeed, I do not find said file in the folder.
The huge file behaves the same in Nero Showtime, playing for only 4.19 sec.
Any clue what may have happened and how I might recover this file? This file may contain crucial evidence that needs to be viewed.
Many thanks in advance for any help you can offer
Last edited by photodyer; 26th Jan 2011 at 10:58. Reason: Left out the fact that I'd tried opening the clip in other software
Have you tried open it with a video editor like avidemux, virtualdub? Only 4 seconds?
I just installed and tried virtualdub; same thing. 4.178 seconds, 342 frames. I'm guessing that ulead did something strange because of the length of video I tried to capture, but I've no idea what.
There was a message in virtualdub about the clip: "AVI stream 0 (video) has a non-zero start position of 12 samples (+147ms). Virtualdub does not currently support non-zero start time and the stream will be interpreted as starting from zero."
A 14 hour uncompressed avi would probably exceed 1TB anyway.
And if it did I suspect there would be so many dropped frames to render the video un-watchable or even trash the HDD in trying to record it for such a long period and at such high sustained data.
So I must ask, why uncompressed ?. Ulead will capture in dvd quality mpeg2. That would only be some 56 gig.Last edited by DB83; 26th Jan 2011 at 13:52.
Even VirtualDub won't capture for more than 8 hours lossless unless you change the "superindex" settings so I'm not surprised something that isn't a dedicated capture app can't do 14-hour uncompressed properly.
There is nothing wrong with Ulead's capture app - use it quite often but only for Mpeg2.
I have had problems with it doing DV - although its own editor can open and use, others can not. Never tried uncompressed for more than a few minutes.
But have you tried opening the file in the Ulead editor ?
Bluray to .avi video bitrate issue
By gartzo in forum Video ConversionReplies: 1Last Post: 1st Apr 2012, 17:08 -
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 07:38 -
screen captured video convrted to mpg dvd - will they be an issue
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2009, 04:32 -
Captured Videos Issue
By Equarter in forum Video ConversionReplies: 18Last Post: 19th May 2009, 19:43 -
Ok, captured my video as AVI format
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 00:37
