Hello everybody,
I'm asking because I am a liitle bit confused. I read some threads on this site and in one of them (https://forum.videohelp.com/threads/330954-mpeg2-ts-file-convert-to-mkv-or-mpeg2-ts-cha...-video-bitrate) it is mentioned that for convertion from ts to mkv two programs should be used (tsMuxer and mkvMerge).
Now my question: isn't vDub not enough for this task (I've been using this program for a while and it's been doing its job very good). Are there any advantages showing up from using above two programs or the results are the same?
I got my TS's from hauppauge hd pvr.
Thanks.
Results 1 to 18 of 18
Tsmuxer and mkvmerge are multiplexers, they are just just putting the video and audio in a different container.
Sent from my Nexus One using Tapatalk -
run that .ts file through HDConvertToX...takes it to an .mkv if you want...works very well
you can also use Multiavchd -
yes it can.
I downloaded latest version 1.9.11 + this file virtualdub.org/beta/DShowInputDriver-0.5.zip
and I can open everything (i think) and save to mkv using ffdshow. -
Does it remux or does it recompress? Remuxing is the process of taking the compressed audio and video streams and repackaging them. There is no loss of quality because the audio and video aren't changed at all. And the process is very fast. Recompressing will reduce the quality and take much longer.
Yes, but when using the directshow source plugin VirtualDub gets uncompressed frames from Directshow. Direct Stream Copying that into an MKV file will give you enormous files -- 20 to 50 times bigger than your source.
Unless you're going to recompress the file then you need to get away from Virtualdub. If you're going to recompress (crop, cut out commercials, resize etc) then you can use Virtualdub but using ffdshow or x264vfw in an avi container is the wrong way to go. The new virtualdub has an external encoder feature that allows you to use commandline encoders and muxers to encode H264/AAC in an mkv or mp4 container. You can also do ac3 passthrough with the right settings and encoder.
Here are the links to the files and settings you'll need to do this...
Virtualdub
http://virtualdub.sourceforge.net/
using the external encoder
http://forums.virtualdub.org/index.p...T&f=3&t=18840&
opening non supported files in Virtualdub with directshow
http://forums.virtualdub.org/index.p...T&f=4&t=18798&
If you have the Hauppauge 1212 HD-PVR then you should think about purchasing Videoredo 4. You can cut all the commercials without having to re-encode the file.
If all you need to do is remux to a different container then all of the advice given from others is the way to go or like Jagabo said, just set the TME software to capture MP4 instead of TS or M2TS.
MKV 3D SideBySide with MKVMerge
By klode in forum Video ConversionReplies: 0Last Post: 12th Jun 2011, 08:54 -
MKV to M2TS w/ TSMuxer
By averageschmoe in forum Video ConversionReplies: 2Last Post: 22nd May 2011, 01:21 -
making mkv using mkvmerge
By selv00201 in forum Video ConversionReplies: 8Last Post: 18th Apr 2011, 13:06 -
Trying to remove subtitles from a mkv with mkvmerge
By vato76 in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2010, 23:53 -
tsmuxer and mkv
By Bazza-61 in forum Video ConversionReplies: 3Last Post: 4th Oct 2009, 21:22
