after editing and exporting, in the exported avi, the sections of the audio track where I used audio adjustments (such as hi-pass and volume keyframes) are producing noises that aren't present in the source audio track, nor in the timeline.
I tried exporting only one clip with audio adjustments, using the work area bar, and the exported track sounded normal, just like in premiere timeline. Only when I export the entire sequence, the resulted audio has theese weird noises, wich are similar to those generated sometimes on audio cd's between the ending of a track and the beginning of the next track.
Results 1 to 1 of 1
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
Audio / Video interleave Adobe Premiere Pro CS3 problem
By mkrmec in forum EditingReplies: 5Last Post: 21st Aug 2008, 08:28 -
Importing a Photoshop CS3 image into Premiere Pro CS3
By paulinnorway in forum EditingReplies: 4Last Post: 17th Apr 2008, 08:54 -
Capturing audio only? (Premiere Pro CS3)
By kingmustard123 in forum EditingReplies: 3Last Post: 25th Feb 2008, 19:29
