Results 1 to 10 of 10
  1. i gave up on ulead. My .m2v file i created will play in windows media player, but when i try to import it into dvdit! it says it can't find a suitable decoder. Plz help, its driving me crazy
  2. Dvd-it will only accept MPG files with MPG Layer 2 Audio in them. Ironically m2v files is what DVDit actually creates from your MPG file but not the other way round.
    Spruceup accepts m2v files as source material, but you'll need the audio file to go with it.
  3. the guide on this website said to load the .m2v file and audio file into dvdit! in order to create the vob's and burn a dvd. Surely there's a way to do this. I might give up and try spruceup anyway cause dvdit seems to lock up sometimes.
  4. Hi,
    first of all i've been in your postion for the last few months, but now i'm racking them productions out on DVD-R
    Which DVD-it product are you using?
    Regarding
    For DVD-it to find a suitable decoder you have to do the following :-
    Rename your m2v to mpv.
    Start to play your mpeg file in windows media player, then pause it DO NOT STOP VIDEO
    Then minimize media player and open dvdit, import file in media section, then "voila" your mpeg will load in DVDit
    Let me know if this sorts your problem.
    Rimmer
    "Smoke Me A Kipper, I'll Be Back For Breakfast!! :D
  5. i'm using dvdit! pe
    I tried what you said but no luck. Is it possible i need to download a different codec? I wouldn't think so since it's playing in media player but i don't know.
  6. also tried mp2, still no luck. I'm using xp pro edition if that might make a difference.
  7. what you need is mydvd get that and you will be fine
  8. Hi again,
    I am also using XP PRO and DVD-it PE, with no problems....I'll yhink over it today and post my thoughts L8r.
    GTG ..BBS
  9. i got my video to load into MyDVD. I don't really like that program, but at least it loaded it. When i preview it everything looks good except the audio is quite a bit behind the video. any ideas how to fix that?
  10. It is a common problem with chapters on dvdit pe, the sound plays but video can't keep up.
    But in reality when its burnt to a disk everythings ok.
    use a dvd-rw first to test it
