Hi I bought Roxiocreator 2010 last year and havent used it yet. If i buy a Hd camcorder that uses the memory cards. Can i just use my card reader to import the AVCHD files into my computer and then edit and burn to dvd's? I read the user guide book and they just talk about arhciving them. From reading the forums it sounds like a lot of work to edit and burn to DVD Bob My computer is athlonII 64x4 on a GA-MA785GM-UU2H mobo with 4 gigs ddr2
I don't think Roxio software is held in high regard on this forum.
You might be able to import the AVCHD videos into MultiAVCHD and create a DVD, there. (I can't remember offhand whether or not it creates a DVD image or actually does burn it for you (with Imgburn).)If cameras add ten pounds, why would people want to eat them?
Import AVCHD files to ROXIOCREATOR 2010
By boblee in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Jan 2011, 01:47 -
Problem importing video files to Editing software
By alistairsmac in forum Newbie / General discussionsReplies: 2Last Post: 16th Oct 2010, 12:15 -
Using proxy files for AVCHD editing - conversion software
By sterankin in forum EditingReplies: 27Last Post: 11th Jun 2010, 05:46 -
Importing files with AC3 sound into editing software
By jeanpave in forum Video ConversionReplies: 10Last Post: 21st Apr 2010, 01:55 -
Smoothness problem while importing avchd files
By effegieffe in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 3rd Mar 2010, 21:55
