  1. i'm trying convert angelic layer eps 11-12 from avi(divx) to mpg using TMPGEnc 12a but it take more than 4 hour and when convert using Panasonic Mpeg Encoder it always error . i'm using Toshiba Satellite Pro 6000,HD 40 GB, 256MB, P3 1.3 Ghz. my qustions why it so slow ??? or do u guys know the fastest software that i can use and where i can download it ?
    thanks
    Illinois, USA
    Video coding is a highly CPU intensive task and takes time and resources. With a P3 1.3Ghz system, I don't know that divx-->mpeg conversion can be done much faster than .5X (twice the amount of time the movie runs). This is especially true if you are using filters or the "highest motion search precision" setting in TMPGenc. As far as encoders, I can tell you that Panasonic takes forever, as does LSX, and TMPGenc is sort of a middling when it comes to speed. The fastest encoder I know of is CCE (Cinema Craft Encoder). . .problem is that it is very expensive (unless you download the crack, of course), and the input video has to be the same resolution as the output, which obviously won't work when going from divx (620x270, etc.) to S/VCD resolution. So, be patient, and exit out of all background applications (especially Virus Scanners), and don't mulit-task if possible. I always encode while I sleep. . .when I wake up the file is done. Good luck!
  3. well thanks but i'm still trying if there's difference between Win XP and Win 98 . i guess Panasonic still better than TMPGenc but on XP i got an Error i don know why...but now i try this program on win 98 i hope not get an error like on XP.
  4. Iwant to go at sleep also,but when i have to split de avi so that he makes to mpeg1 cd's,is it then possible that he make's both file's so i can burn them later ore must he first make one en then i have to configer the second one?
    Thx From the Netherlands;-) :o
