I've been using EasyCap for awhile now and want to to upgrade to something to record my Wii and Xbox 360 at the best quality. The dilemma is I have no method to set up a TV in the same room as my computer. So I need to able to capture and play on my monitor. For my easycap i use honestech VHS to DVD to record but I want something that can capture 480p and/or 720p. However most higher-quality capture software I have seen has a delay between my input and seeing it onscreen. What would be the best device+software combination to record at progressive quality? Any help or advice will be appreciated.
My computer specs are:
Vista Home Premium
Intel Core 2 2.13Ghz
4GB RAM
Results 1 to 19 of 19
Take a look at the 'Capture Cards' list to the left of where you read this.
Enter your options and you will arrive at the Black Magic Intensity Pro. A sniff at a mere $250. -
Personally I'd recommend a hauppauge hd pvr - though it is component only and dolby digital only (will do 5.1 via fiber optic but not dts).
Its a usb box that you connect externally to your computer by the way.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Black Magic is currently way out of my budget. I've looked into HD PVR before. Theres up to 4 seconds delay between input and display on the monitor. I do not have a TV I can set up in the same room as computer. What I am looking for is an HDMI or component capture card that I can record with but without any delay while recording. I can deal with audio delay but since I'm recording game consoles I can't allow any video delay.
The problem is that 'good' and 'cheap' rarely go together.
Yet a 'good' capture device should not have any delay that you describe unless you are filtering the feed through other devices. -
http://www.kiva.org/about -
That's the ideal setup but unfortunately not possible in my circumstances. I have no place for a TV in my computers room and nowhere to set up computer near my TV. The only way I will be able to do that is if I buy a borrow laptop. Delay most often has to do with software being used to capture. For example Trying to use Pinnacle Studio with my easycap will give me delay whereas honestech vhs to dvd will not. My primary concern is a way capture 480p/720p video with minimal delay
Yeah, what inputs are available on your monitor?
DB83, there is another HDMI capture card that's cheaper, the AVerTV HD DVR. But I don't think that or the BM card really apply in OP's case since it looks like he has an older dual-core. -
jargus,
With so many constraints, your expectations are too high. What is your actual budget? $10US? $200US? What is your desired destination? Email to friends? Web streaming? Youtube? Distance from console to computer? What is your monitor? (Looking for number and types of input).Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Maybe:
http://www.amazon.com/Avertv-Definition-Analog-Capture-MTVHDDVRR/dp/B002SQE1O0/
http://www.amazon.com/review/R2ZTUAO59SLFEW/ref=cm_cr_pr_perm?ie=UTF8&ASIN=B002SQE1O0&...tag=&linkCode=there is no noticeable lag at all while playingLast edited by jagabo; 25th Jan 2011 at 11:02.
You won't be able to get Wii captures from that, hdmi only. You'll need an analog to digital converter... not cheap.
You need something with component (Wii 480p) and HDMI (360 720p).Last edited by neomaine; 25th Jan 2011 at 14:40.
Have a good one,
neomaine
It has analog inputs: composite, s-video, and component. One of the connectors that looks like HDMI isn't HDMI, it's for a pigtail adapter. From the description at Amazon:
It’s equipped with HDMI and through the included dongle cable, Component, S-Video and Composite Video -
"Noticeable" lag is the key word in that review. Someone actually measured it here: http://www.avsforum.com/avs-vb/showthread.php?p=18394593#post18394593
Depends what games you're playing. It's enough to feel when playing Rock Band. Not noticeable going through menus. Haven't yet tried playing other games through it. -
Have a good one,
neomaine
What is a good DVD Recorder that has Component and/or HDMI Input(s)?
By KingKRool2002 in forum DVD & Blu-ray RecordersReplies: 37Last Post: 26th May 2008, 20:08 -
Game Consoles & Capture Cards
By Bonici in forum Capturing and VCRReplies: 4Last Post: 15th Jan 2008, 18:59 -
Are cheap HDMI cables just as good? What about component?
By Fearnot in forum DVD & Blu-ray PlayersReplies: 14Last Post: 17th Dec 2007, 09:27 -
Capture HD from your game consoles for around $300 (480p/720i/p/1080i/p)
By Mysteriouskk in forum Capturing and VCRReplies: 4Last Post: 22nd Oct 2007, 19:00 -
Good Card for Video Game capture
By npsken in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2007, 07:55
