Results 1 to 12 of 12
  1. I want a still image for a dvd background .....I cant find a decent Jpeg Bmp...so i have got these pictures..
    http://lulzimg.com/i09/ce69cf.jpg
    http://lulzimg.com/i09/edea02.jpg
    i want to blend this one into them somehow
    http://lulzimg.com/i09/17b9b5.jpg
    Whats A newb easy way to do this please....maybe there is somewhere online i could do this.. and even better would be a full guide if avaliable
    Thanks in advance
  2. What do you mean by blend? Do you want one picture overlaid on the other with 50 percent transparency? Or do you want them side by side?
  3. Yes i want the bottom one over layed on one of the top ones..i got this far as i foind http://www.online-image-editor.com/
    http://lulzimg.com/i09/af0a5b.jpg
    ...but i want it so as the night sky overlays the white on the Jpeg..essesntially so that all that is seen is the characters faces and text..
  4. I'm still not quite sure what you want. This is quite crude, but do you want something like this?
  5. Member Cornucopia's Avatar
    I'm guessing you want something more like this:
    This uses Blending Modes. There are many kinds (Normal, Overlay, Difference, Color Dodge,...). Once you try it out with the upper layer using a mode other than Normal, and possibly with a reduced level of opacity, you'll probably be able to get what you're looking for.
    You'll need a photo editor that supports Layers and Blending Modes and Transparency. The editor of choice is Photoshop, but you can even do it with freeware tools, I chose my example below using Paint.Net. Gradient Masks added to the upper layer would probably have helped out with the legibility of the text, but I was in a hurry. You know, this looks alot like those old openings for "McMillan & Wife" or "McCloud". Kind of appropriate, eh?
    HTH,
  6. How do you get the faces trimmed out of the background so evenly. I've tried Photoshop and always seems to look like the top trim job unless I spent hours moving all the points and still leaves a sharp edge whereas yours seem more blended (I realize it's because you know what you're doing)---any good books for Photoshop for the beginner besides the same old ones with the boat you have to copy and paste?
  7. He just marked one of the images as 50 percent transparent and overlaid it on top of the other.
  8. Sometimes I go to this site if I'm stuck on something in Photoshop.
  9. Im sorry i have not explaned it clearly as i have no background or have ever used image editors..But alas we got there ... Thanks Jagabo.. i like it and im wondering now if maybe thats the way to go..looks beter in my honest opinion..but Cornucopia has got what i was looking for..ill have to find a better quality pic of the guys as i want that a bit more vivid stand out..if you know what i mean ...i guess ill have to read up on items and methods mentioned..Thanks for the help
  10. Didn't notice the double overlay in parts. It thought it was trimmed like the top one only better with a clipping path.
  11. Member Cornucopia's Avatar
    Nah, it's just a 60% opacity on the top layer, and "Color Dodge" or similar blend mode. Resized the top layer, too, 'cause it was alot smaller than the other image. Took about 3 minutes to put together (since I wasn't used to where Blend Modes resided on Paint.Net). Would take about 30 seconds in Photoshop. I STRONGLY recommend photoshop (the pro version, maybe not so much the Elements version). Heck, it's even worth your while to get an old version on eBay or something. Anything version 5 or 6 or higher will do you well.
  12. If I was doing this seriously I'd make an alpha mask semi manually, then overlay the faces+alpha over the bridge in the background. That takes a lot of time to do so in my sample image I just quickly painted the parts I wanted to be transparent black. Then set black as transparent in the overlay.
