Results 1 to 10 of 10
    Oct 2005
    Australia
    I'm curious as to what software the community here favours for playing Bluray disks?
    I'm using TMT currently.
    Feb 2008
    Twin Peaks
    I still use the Cyberlink hi-def suite that came with my pc.
    Nov 2003
    West Texas
    TMT 3 for me. Are you using the newer TMT5?
  4. Mod Neophyte redwudz's Avatar
    USA
    I also use TMT3. Not really that happy with it, but there's not many alternatives out there, especially ones that can play from a file.
  5. I go with TMT5 these days for my PC. Overall, Arcsoft tends to be more receptive to consumers from my experience. Whenever I've actually run into an issue Arcsoft has gone out of their way to help resolve things. Cyberlink has done nothing more than blow me off over the years when I tried to report and get an issue fixed. Corel is simply a joke when it comes to WinDVD.
    TMT isn't infallible but it definitely is more stable on my systems than either PowerDVD or WinDVD. Plus with TMT you can play all your copied discs from folders rather than having to mount images. You also have HD-DVD support even though it's not truly official. It's just a bonus.
    May 2001
    CHEERS GARRY
  7. Arcsoft TME for Blu-Rays.
    MPCHC for everything else.
    Pull! Bang! Darn!
  8. PowerDVD 9 that came with a combo drive. I'm too cheap to buy anything, particularly since we only have a handful of Blu-Ray discs.
    Jul 2001
    Originally Posted by garryward View Post
    Same, or, through WDTV Live
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  10. Member yoda313's Avatar
    Jun 2004
    The Animus
    windvd for me on the pc. However I almost never watch on the pc. I use my ps3 mostly.
