I have an .asf file from Bonnaroo concert that used to play fine. Now all players give error.
I'm guessing this is drm in effect.
So how do I get around this?
I tried win 7 medi player, vlc, kmplayer, medi player light.
Complete name : \\BlackKeys.asf
Format : Windows Media
File size : 305 MiB
Duration : 44mn 37s
Overall bit rate mode : Constant
Overall bit rate : 955 Kbps
Maximum Overall bit rate : 62.4 Kbps
Encryption : https://blueroom.istreamplanet.com/drm/blueroom.asp
Encoded date : UTC 2007-06-16 16:19:11.265
Video #1
Format : VC-1
Format profile : MP@ML
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9
Duration : 44mn 37s
Bit rate mode : Constant
Bit rate : 436 Kbps
Width : 480 pixels
Height : 270 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.112
Stream size : 139 MiB (46%)
Language : English (US)
Video #2
Format : VC-1
Codec ID : WMV3
Duration : 44mn 37s
Bit rate : 268 Kbps
Width : 480 pixels
Height : 370 pixels
Display aspect ratio : 1.297
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.050
Stream size : 85.5 MiB (28%)
Video #3
Format : VC-1
Format profile : MP@LL
Codec ID : WMV3
Duration : 44mn 37s
Bit rate : 80.0 Kbps
Width : 250 pixels
Height : 140 pixels
Frame rate : 15.000 fps
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.152
Stream size : 25.5 MiB (8%)
Video #4
Format : VC-1
Codec ID : WMV3
Duration : 44mn 37s
Bit rate : 29.0 Kbps
Width : 178 pixels
Height : 100 pixels
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.108
Stream size : 9.24 MiB (3%)
Encryption : Encrypted
Audio #1
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9.1 - 12 kbps, 8 kHz, stereo (A/V) 1-pass CBR
Duration : 44mn 37s
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 20.4 MiB (7%)
Audio #2
Format : WMA
Codec ID : 161
Duration : 44mn 37s
Bit rate : 32.0 Kbps
Bit depth : 16 bits
Stream size : 10.2 MiB (3%)
Audio #3
Format : WMA
Codec ID : 161
Duration : 44mn 37s
Bit rate : 20.0 Kbps
Sampling rate : 16.0 KHz
Bit depth : 16 bits
Stream size : 6.38 MiB (2%)
Audio #4
Format : WMA
Codec ID : 161
Duration : 44mn 37s
Bit rate : 12.0 Kbps
Sampling rate : 8 000 Hz
Bit depth : 16 bits
Stream size : 3.83 MiB (1%)
If you don't have a valid drm key/license you can't do much.
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 14:11 -
suspisious ASF-AVI file
By roberta in forum Video ConversionReplies: 1Last Post: 15th Aug 2010, 17:18 -
ASF file conversion woes
By andy99 in forum Video ConversionReplies: 5Last Post: 8th Dec 2008, 18:41 -
help on .asf file conversion
By fabpozzi in forum Video ConversionReplies: 5Last Post: 23rd Jun 2008, 20:13 -
ASF file conversion
By sawm24 in forum Video ConversionReplies: 7Last Post: 11th Aug 2007, 09:47
