As the title says.
I have some videos that I want to put on DVDs. They have 3 Audio Streams and 5 Subtitle streams on them. I need a program that can convert them so that I can access the different Audio and Subtitles on my PS3. I've converted other dual-audio things and single audio with softsubs and I can never access the other audio or ANY subtitles.
ConvertXtoDVD is about the only thing I can think of that may do that many streams. Most of the others will do one or two audio streams and one or two subtitle streams only.
Generally, after conversion, you will have to use the audio and susbtitle buttons on your remote to change streams.Read my blog here.
Thanks, it looks good (and kind of expensive, but if it works I will buy it)
But does the subtitles and audio on the output file work on a PS3? I've tried a lot of programs to encode to MP4 and AVI and such, and the alternate subtitle/audio stream doesn't ever show up on the PS3 menu. (It simply defaults to stream 1 with no subtitles) -
Do you want a DVD Video disc, or just files you can play ?
ConvertxtoDVD will create DVD Video discs. MultiAVCHD can create DVD or AVCHD video discs that can support multiple audio and subtitle streams.
Other formats can support some of these features, but playback may not support all of them. E.g. MP4 can contain multiple audio tracks, and the PS3 can switch between them, but subtitle support is much more limited. Again, you have to switch between the streams by using the remote (triangle button during playback brings up a menu that allows you switch audio and subtitle streams where available). The PS3's ability to handle subtitles is limited outside of authored discs. It won't play external subs at all.
The most flexible single file format is probably M2TS, which has a big overhead for muxing, but can handle multiple audio and subtitle streams, and the PS3 can play these from USB keys or HDD. The only issue with the format is DTS audio, as the PS3 appears to only play DTS audio from authored discs (certainly true for HD DTS audio)Read my blog here.
Help with MKV files with multiple audio and subtitle tracks.
By razzn in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 17:59 -
convert MKV files to PS3 w/o losing subtitle attributes
By Looney in forum Video ConversionReplies: 6Last Post: 28th Nov 2010, 18:37 -
mkv to mp4(ps3) subtitle issues
By HeroSmero in forum Video ConversionReplies: 2Last Post: 3rd Jan 2010, 20:43 -
DVD to MKV with multiple audio & subtitle streams?
By RarelyEvil in forum DVD RippingReplies: 1Last Post: 18th Jun 2009, 11:30 -
MKV conversion with multiple audio tracks???
By KrakaJap in forum Video ConversionReplies: 4Last Post: 26th Apr 2008, 19:25
