Any one have these units? Looking for info on file types and sizes it will play though the memory stick. Region free hack would be cool too.
	From caraudioxperts.com:
 • DVD, DVD-R, VCD, SVCD, CD-DA, CD, CD-R/RW, MP-3, DiVx, AVI, WAV
 • LCD screen resolution: 640x234
 Other sites in my search, including poweracoustik.com, give less info...
 So DivX AVI should be possible if caraudioxperts.com is right.
 I guess you'll just have to try a bunch of test files at different settings to find out its limits.
	Have anyone installed headrest car dvd before? I just want to install two headrest car dvd for my Ford. Before I buy them, I want to know the steps about the installation work. And I plan to buy this one: 7 inch Digital Car Headrest DVD Player with USB/SD/GAME/IR/FM transmitter. http://www.justcardvd.com/products/7-inch-Digital-Car-Headrest-DVD-Player-with-USB%7B4...ansmitter.html Is that ok?
 [Attachment 18088 - Click to enlarge]
	NOBODY is going to talk you through the installation steps here. There are websites that tell you how to install your own car audio devices if you want to try to do it yourself.
 I will be very blunt with you - I know how to do this kind of work, but if you don't do it all the time it is VERY time consuming and it's one of those things where if you have to ask how to do it, you probably won't be able to do it yourself. The best advice I can give you is to disconnect the car battery before you start working as it's fairly easy to short out and ruin things if you don't. If you've never done this before, it will very likely take you between 4 and 8 hours to do it. You might think about whether it's really worth your time and labor to do it yourself rather than pay a professional to do it.
	I also know nothing about the model you intend to buy, so I have no comments to make about it.
  Help needed: Region hacking Invision (LiteOn?) Headrest DVD PlayersBy matho in forum DVD & Blu-ray PlayersReplies: 25Last Post: 14th Jun 2017, 01:18
  ripping HDVD-9 to DVD???By kenyaly in forum DVD RippingReplies: 3Last Post: 31st May 2011, 21:57
  DVD player is getting power but I can't get any sort of pictureBy Rhiannon in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd May 2010, 22:33
  How to dezone a Mac Power book DVD Player?By Romain in forum MacReplies: 22Last Post: 17th Jun 2009, 05:33
  DVD Player with USB HDD (Non external Power) supportBy fayewolf in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jan 2009, 22:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
