All,
When i connect my LaCie media device to my samsung tv using the yeloow red and white input the colour on the movies flas constantly from normal colours to completely saturated colours making it unwatchable any ideas
thanks from a newbie
With all Divx files or just a particular file? What about other types of video? What about when sitting at the UI?
All files streaming of the media player, when i connect same player and cables to other tv it works perfectly so it must be a tv issue
thanks for your responce -
It sounds like some incompatibility between the player and TV. That's very unusual though. Can you use s-video component video instead? Also make sure the device is set to output PAL video, not NTSC or PAL60.
both tvs are Samsung, the media player is perfect on one but the colours flash on the other one, Ill check the device settings as you suggest, it has no s-video just hdmi and composite, i thought it might be a specific setting on the tv
thanks again -
There could be a problem with the TV's composite input. Have you tried other devices connected to that input?
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Problem with DivX yet works in Windows Media Player
By tmundrill in forum Software PlayingReplies: 1Last Post: 18th Oct 2009, 07:44 -
Media Player Classic audio playback problem
By qpskfec in forum Software PlayingReplies: 2Last Post: 3rd Dec 2008, 15:09 -
Video Problem with Divx/Xvid files on Media Player
By Vid-Kid in forum Media Center PC / MediaCentersReplies: 2Last Post: 16th Dec 2007, 23:09 -
Problem with DVD Playback on Windows Media Player.
By Cereal Bawks in forum Newbie / General discussionsReplies: 5Last Post: 29th Jul 2007, 16:11
