Gday,
I have a Promise TX4650 SATA Raid card and would like to use this to add 4 more 2TB HDD's to my pc... The "problem" is that it seems that I cannot use the drives as "normal" drives with this card and it HAS to be set up in a RAID array or JBOD... If anyone knows how to set it up so the drives would be K:, L:, M:, and N: could you please let me know..
I have already used the 6 ports available on my motherboard (ASUS Striker Extreme).. The other possability is by using a port multiplier, but have been told that it may not be compatiable with the controller on the mobo as the controller HAS to be ok with a port multiplier..
ANY help is appreciated..
James..
From what I can find, that is a RAID only card. It doesn't support single drive setup.
Google is your Friend -
You need something like a PROMISE SATA300 TX4 PCI SATA II (3.0Gb/s) 4-Port Adapter. I have a couple of these and they work fine with individual SATA drives, no RAID.
"JBOD" stands for Just a Bunch of Disks. No real RAID. That's what you want. So, whether or not it is telling you that JBOD is a type of RAID, it isn't. If that's one of your choices, it's safe to choose it.
P.s. Every RAID card I've ever used (prolly 8-12) has ALWAYS had a straight JBOD option.
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 04:13 -
RAID controller question...
By RogerTango in forum ComputerReplies: 12Last Post: 21st Oct 2011, 23:59 -
Need recommendation for a pci raid controller card
By mysts in forum ComputerReplies: 16Last Post: 4th Jan 2010, 21:03 -
Multimedia Controller
By angryassdrummer in forum ComputerReplies: 15Last Post: 6th Nov 2007, 10:45 -
VOB Question (last one i promise)
By jordanwalkert in forum EditingReplies: 1Last Post: 8th May 2007, 02:37
