I have downloaded my .mov files from Revver.com, which is going down the tubes, and I'd like to upload them to Youtube. But Youtube doesn't recognize the .mov files as valid videos. I think there is something small wrong with the files. I can convert it only with MyVideoConverter - and I tried a bunch of others. But I'd like to use the original file since the conversion degrades it so much. What do you recommend? How should I fix these files? Or convert them losslessly?
I've attached a sample .mov so that you can see for yourself.
Thanks.
start over again with the original sources and create mp4s for youtube. any kind of re-conversion will lower the quality.
@zyistra
Those mov files contain 5 tracks:-
1 JPEG
2 RLE
3 MPEG-4
4 AAC
5 Text
That's why YouTube won't accept them.
You can use MKVmergeGUI (mmg) to create new mkv files containing only tracks 3 and 4 of the original files.
This is lossless conversion.
Then upload the mkv files to YouTube.
From here:- http://www.bunkus.org/videotools/mkvtoolnix/
Instructions are here:- http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge-gui.html#whatismkvmergeLast edited by bat999; 22nd Jan 2011 at 08:43.
bat999, you're outstanding! I've got it working via the command line since I've got to process many files, but I can't get the batch file to process many files at once. Do you know any Windows scripting?
I'm using the following, as an example, for one file:And for multiple files I've tried the following, but it doesn't work:Code:mkvmerge -o 293497.mkv -d 7 293497.mov
Do you know how to do this?Code:for %m in (./*.mov); do set mkvfile="$(echo %m | sed 's/mov/mkv/')"; mkvmerge -o $mkvfile -d 7 %m; done
Thanks. -
Hi
This command really does work OK for one file:-
This is the batch command that I'd use WITH LINUX:-Code:mkvmerge -o 293497.mkv -d 7 293497.mov
I don't know the Windows syntax.Code:for f in *mov; do mkvmerge -o "${f%.mov}.mkv" -d 7 "$f"; done
Thanks, bat999. A friend of mine just replied in an email with a command that worked for me:
For others who may want to use this exact command remember that the mkvmerge files and folders should be in the same folder as the videos to be converted.Code:for /f %a IN ('dir /B *.mov') do call mkvmerge -o %~na.mkv -d 7 %a
Cant upload video to youtube
By Florida in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2011, 01:33 -
How to upload more than 10 min on YOUTUBE
By 3thman in forum Video Streaming DownloadingReplies: 5Last Post: 6th Mar 2010, 15:59 -
How to record TV and upload on youtube
By magic_impuls in forum Capturing and VCRReplies: 3Last Post: 25th Mar 2009, 22:46 -
Join mov files and upload to youtube
By neelapala in forum EditingReplies: 2Last Post: 23rd Dec 2008, 12:09 -
Which format to upload to youtube for HQ?
By Captain Satellite in forum Newbie / General discussionsReplies: 8Last Post: 29th Mar 2008, 12:54
