So after giving up on making my LCD TV to work directly with a Verizon Set-Top-Box, I am now looking into
using a USB TV Tuner to watch TV on my laptop (and then connecting this to my LCD monitor).
I am looking at these 2 devices: http://www.radioshack.com/search/index.jsp?kwCatId=&kw=usb%20tuner&origkw=USB%20Tuner&sr=1
Now, my main question is : If I hook up the coaxial output from my STB through this
USB stick into my Laptop will I be able to view in HD ?
Thanks,
Gotham
It depends where you're from. This seems to work, or not work, depending on where you live - and I can't say for sure whether it's directly from your wall or from your STB for broadcast quality, or in analog directly from your STB (or even from your wall).
As for HD, it also depends on your laptop if it can handle it.
But if it promises tuning, then try all options and see what works in your area.
And I would pick Hauppauge over Pinnacle any day. Hauppauge has more credibility in its products IMO.I hate VHS. I always did. -
The Verizon set-top box only outputs SD over its coax out on analog channel 3 or 4, which means HD isn't possible from that source. Assuming it's an HD STB with component out, there are only two choices for a USB HD capture device.
http://www.hauppauge.com/site/products/data_hdpvr.html
http://www.avermedia-usa.com//AVerTV/Product/ProductDetail.aspx?Id=488 -
If you don't need video capture you probably want something like this:
http://www.amazon.com/gp/product/B000XY6N5Y/ref=ord_cart_shr?ie=UTF8&m=A2LM6ZPY06LT1N
No HD though.Last edited by jagabo; 21st Jan 2011 at 18:56.
Do you have Vertizon HD service? Why did you give up on Verizon?
The channels you will get with a USB2 tuner are the SD analog cable channels plus the local clearQAM SD/HD cable channels. The latter requires the tuner have clearQAM support and you may find it difficult to find them. These tuners also pick up over the air ATSC if you put up an antenna.
If you get an HD set top box from Verizon, you will get all the HD channels in the subscribed plan. You connect the HD cable box to the LCD-TV with analog component or HDMI cables.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Samsung micro USB-B to USB-A cable
By luigi2000 in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2011, 14:05 -
Analog Cable TV to HD LCD Monitor via TV tuner
By torrentkid in forum DVB / IPTVReplies: 0Last Post: 3rd Aug 2010, 06:19 -
Cable tv shows through when I watch satellite
By szalaikornel in forum DVB / IPTVReplies: 0Last Post: 19th Feb 2009, 15:09 -
whrist watch usb
By Finlay in forum Off topicReplies: 0Last Post: 4th Nov 2008, 11:05 -
Recommendations for a USB Cable Tuner
By Boegy3 in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2008, 13:21
