Results 1 to 9 of 9
  1. I'm ripping home movie DVDs that I made several years ago. These DVDs have chapter points to delineate the various videos on the disk (not separate vobs). I'm ripping the DVD so it is broken into the various videos using the chapter points. However, most (but not all) of the videos end up with missing headers (according to ffmpeg). This isn't usually a problem except on the PS3 where the video plays fine, but there's no sound. I've tried ripping with both DVDShrink and DVDFab with the same result. So, does anyone know of a solution that will rip a DVD by chapter points and maintain the headers? Or maybe some way of reconstituting the headers on the videos where they're missing?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVDDecrypter
    IFO Mode
    File Splitting - BY CHAPTER(though it gets trickier with multi-title discs).
    Load one of your ripped "chapters" (BEFORE any further processing) into GSpot and post the results.
  3. OK, here it is:
    File Information ---
    File Name: noheaderDVDDecrypter.vob
    File Name (with full path): C:\noheaderDVDDecrypter.vob
    File Size (in bytes): 78,626,816
    --- Container Information ---
    Base Type (e.g "AVI"): MPEG (.MPG/.MPEG/.VOB)
    Subtype (e.g "OpenDML"):
    Interleave (in ms):
    Preload (in ms):
    Audio alignment("split across interleaves"):
    Total System Bitrate (kbps): 10080
    Bytes Missing (if any):
    Number of Audio Streams: 1
    --- Video Information ---
    Video Codec Type(e.g. "DIV3"): MPEG2
    Video Codec Name(e.g. "DivX 3, Low-Motion"): MPEG-2
    Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are Installed
    Duration (hh:mms): 1:39.133
    Frame Count: 2971
    Frame Width (pixels): 720
    Frame Height (pixels): 480
    Storage Aspect Ratio("SAR")" 1.500
    Pixel Aspect Ratio ("PAR"): 0.889
    Display Aspect Ratio ("DAR"): 1.333
    Fields Per Second: 59.940
    Frames Per Second: 29.970
    Pics Per Second: 29.970
    Video Bitrate (kbps): 5999
    MPEG-4 ("MPEG-4" or ""):
    B-VOP ("B-VOP" or ""):
    QPel ("QPel" or ""):
    GMC ("GMC" or ""):
    NVOP ("NVOP" or ""):
    H264 ("H264" or ""):
    Quality Factor (bits/pixel)/frame: 0.579"
    MPEG-2 ("MPEG-2" or ""): MPEG-2
    Interlaced ("I/L" or ""): I/L
    Progressive ("Prog" or ""):
    Top Frame First ("TFF" or ""): TFF
    Bottom Frame First ("BFF" or ""):
    3:2 Pulldown ("3:2" or ""):
    Picture-per-field ("PPF" or ""):
    --- Aspect Ratio Related ---
    Broadcast standard: "PAL" (else blank)
    Broadcast standard: "NTSC" (else blank) NTSC
    src:"VCD", "SVCD", "CVD", or "DVD (else blank): DVD
    Instructions to convert to VCD, first part: Resize to 360 x 240 ( w:[1/2] h:[1/2] )
    Instructions to convert to VCD, second part: Trim 4 from each side for 352 x 240
    Instructions to convert to SVCD, first part: Resize to 480 x 480 ( w:[2/3] h:[1/1] )
    Instructions to convert to SVCD, second part: No cropping req'd
    Instructions to convert to CVD, first part: Resize to 360 x 480 ( w:[1/2] h:[1/1] )
    Instructions to convert to CVD, second part: Trim 4 from each side for 352 x 480
    Instructions to convert to DVD, first part: No resize req'd
    Instructions to convert to DVD, second part: No cropping req'd
    Instructions to convert to AVI, first part: Resize to 656 x 480 (Use +/- for other target sizes)
    Instructions to convert to AVI, second part: Crop off any non-picture areas, if req'd
    --- Audio Information ---
    MPEG Stream ID (e.g. "0xbd"): 0xc0
    MPEG VOB file Substream(e.g. "0x80"):
    Audio Codec (e.g. "AC3"): MPEG-1 Layer 2
    Audio Codec Status (e.g. "Codec Is Installed"): Codec(s) are Installed
    Audio Sample Rate (Hz): 48000
    Audio Bitrate(kbps): 224
    Audio Bitrate Type ("CBR" or "VBR"): CBR
    Audio Channel Count (e.g. "2" for stereo): 2
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Run that noheaderDVDDecrypter.vob through VOB2MPEG.
    Which frontend are you using with FFmpeg?
  5. Unfortunately, vob2mpg doesn't take vob files, but only ifo files, and the free version does not allow ripping by chapters. So I can't do as you suggest.
    As for FFmpeg, I've been using the command line.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Oh....you took it out of the DVDShrink output folder already. Well then my normal procedure in that case is to open it in MPEGVCR and save it as an mpeg file(No re-encoding is done).
    I would also consider WinFF as a frontend....I just tried it and it opens VOBs.
  7. MPEG-VCR has a lot of options. How exactly do I open it and then save it as an mpeg file?
    OK, I figured out how to do it, and it does fix the problem. My problem now is that I've got hundreds of these to do. Does MPEG-VCR have a batch function?
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    VOB2MPG will do IFO or VOBs, just choose the mode you need to work in. Yes, you need the Pro version for chapter extraction though.
    Read my blog here.
